You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Has anyone tried adding salt to WVO?
I did a test on some crappy looking WVO. I added some water softener salt and let it sit over night. All the crap is now on the bottom and the oil looks great.
The question is does the salt stay in the crap or is there some salt in the WVO.
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
You could probably wash the oil and get the salt out. If there's anymore added by your process. I would think WVO would be full of salt and other crap disolved into it.
jimbo
__________________ WANTED: Someone to go back in time with me. You'll get
paid after we getback. Must bring your own weapons.
Safety not guaranteed. I have only done this once before. www.jimkidd.com
I tested this on WVO that would not clear up with heat. The issue was not the water but the large amount of small particles that hold the water.
After I added the salt and let sit for 20 hours the all the small particles were on the bottom and the oil was clear.
__________________
I am working on my first 55 gal. drum of WVO that I filtered with 15 micron and moved it to a 55 gal. drum with some salt and baking soda. I plan to let that sit for some time....weeks, then filter 1 micron to final drum and heat, cool, pump from top leaving bottom 1/3.
I have read on Greasecar site that the salt and bs do work.
__________________
03, CC,F350,DRW,SB,4WD,7.3,AFE II Pro 7,CCV MOD,THREE GAUGES,4739, DP TUNER with Permagrin setting, 5" Cannon, Zodad, AIH Delete, Power Slots, Hawks. TCLUS. Coolant Filter, Sonnix, Fuel Pump Shim.....SOLD
__________________
