71-72 Grille Inserts - Ford Truck Enthusiasts Forums
Old 01-27-2002, 09:04 AM
bightrucker bightrucker is offline
bightrucker is starting off with a positive reputation.
I recently saw a pair of 71 grilles inserts for sale. They were listed as stainless steel, after checking them out I found that they were actually plastic as they should be, but had a stainless cover or cap on the leading edge. Was this a dealer dress up item? Aftermarket? Did anyone buy a 70-72 truck new and have this feature?
Thanks, Harold
Old 01-27-2002, 09:41 AM
oleblue70 oleblue70 is offline
oleblue70 is starting off with a positive reputation.
All '71 Fords had that trim on the plastic i am sure.After the 70 they probably thought lets dress up those waffle irons!
Also,
The '71-72 grille shell are different.The mounting tabs for the grilles are deeap and the 70 shell has shallow tabs.
Old 01-27-2002, 09:12 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
A decent 71 grille Coastal68 1967 - 1972 F-100 & Larger F-Series Trucks 5 02-24-2016 07:38 PM
71 Grill Insert Fix to Mount Stainless Trim Bar HIO Silver 1967 - 1972 F-100 & Larger F-Series Trucks 8 02-23-2016 08:59 PM
92-96 Grille (Fire/Rescue/Ambulance) ncranchero 1987 - 1996 F150 & Larger F-Series Trucks 38 11-01-2015 01:16 PM
Wanted: 72 Grill Joeceno 1967 - 1972 F-100 & Larger F-Series Trucks 17 12-09-2014 01:18 PM
F150 replacement grille/insert silver lariat Aftermarket Products 4 01-30-2008 10:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
