Wet shot Nos
a wet setup is when you add fuel along with the nitrous at a nozzel somewhere in the intake hence the "wet" nos kit. when you add it to the injectors this is called a direct port set up since the nos is flowing directly into the port. this is usally the best setup but more expensive since you have to have adaptors for the injectors and the nos nozzels. also is the "dry" set up which is the easiest cheapest but it is easier to run a lean condition since you are only injecting nos into the intake.
so to answer your question you need to run it into the intake somewhere, if you put nos threw your fuel rail it can be very bad. most people run it right before the throttle body because it dosent have to travle far threw the intake.
sorry for the long post but i wanted to try and exlpain for others a little who will read this and wonder some of the same questions and im sure that others will have some imput also and maybe clear up something i didnt or corect me if im mistaken thats the great thing about this site
tony
tony
pizzaboy27
03-14-2004 04:45 PM
