delay when putting into gear
Old 06-02-2006, 04:39 PM
yellow72f100's Avatar
yellow72f100
yellow72f100 is offline
What causes about a 3 second delay when putting my automatic trans. into gear? (reverse or drive). I put the truck in reverse and a few seconds later it "pops" backward into reverse. Nothing violent just delayed.
Old 06-02-2006, 05:38 PM
stuart1's Avatar
stuart1
stuart1 is offline
You don't mention what kind, year, mileage so I will give you generic answer.
Low fluid level.
Engine idle too slow.
Worn, hard internal seals.
Old 06-02-2006, 07:21 PM
yellow72f100
sorry, it's a C-4 in a 1972 F-100 with a 302
Old 06-02-2006, 08:29 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
How is it once it's in reverse? Does it shudder at all when backing up a hill? Does it shudder in any other gears?
Make sure you run Type F fluid only in this transmission, as Mercon will kill it pretty quick.
Old 06-03-2006, 08:52 PM
FordBoypete's Avatar
FordBoypete
FordBoypete is offline
Make sure your TVR is resting on its' stop, you have reccommended RPM at idle, your Manual shift Linkage is adjusted correctly & is reasonably free of play or slop. . . . If it all is right, and you have a delay, without chatter, or a slam shift on engagement, then
your Reverse Band or Servo my be too loose & need adjustment or reverse link could be bent or getting ready to let go.
FBp
Army321
1978 - 1996 Big Bronco
05-06-2016 11:19 AM
stimm32
1999 to 2016 Super Duty
06-23-2014 11:36 PM
boonie
02-13-2007 06:01 PM
Brian460
09-22-2006 10:25 AM
hookspacken
03-03-2003 08:16 PM
Quick Reply: delay when putting into gear
