Good luck reinstalling the clip! Very difficult although u may be luckier than I and most folks. After i lost my clip i ended
up removing the red pressure line to the wastegate actuator cannister. Then i tightened down the tension on the spring and wha!...big time boost! Beware...this could shorten turbo bearing life.
Nut
i found the cork screw from a swiss army knife and a small mechanics mirror was just the trick. be warned you will probably loose the clip. i did find the clip after i took it off and it popped right back on after i adjusted the actuator rod.
Anyway, got the clip to pop off with a small screwdriver. I had a hard time reaching back there (big hands), but I eventualy managed. I put it back on again with a screwdriver managing to prop my thumb up against it and leverage until it snapped into place. Thanks again to Jeremy for the Banks Big Head!!!! I also installed a set of Bilstein 5100's as well, now time to take it for a test drive.
__________________
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's
Your connection to the Colorado diesel community.
Bilstein 5100's are great. im going to retorque all of my stuff this weekend. i love the 'steins, they make the truck feel a whole lot lighter and nimble, but it's still big.
if anyone needs any of these "jesus clips", pm me, i have a few new ones laying around i can mail to you if you need them. i think.
__________________
7.3 fully built longblock for sale PM me
A small mirror helps you see the clip so you can stick the point of the pick into the small hole in the middle of the backside of the clip, then pull and it comes right off.
Reinstalling the clip... don't. Just throw it away and get a pack of Napa Circular Linkage clips (part number 7352640) for a couple bucks. The clip you need from the pack you can reinstall with your finger tips, as you just drop it on over the top, and push to one side and it slides into place. You can take it on and off vary easily if you want to adjust the Big Head.
Looks like you've already got it done.... but oh well... future reference for whoever else can use it.
__________________
Ryan Arthur
* Sold * 2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator/tee, ATS housing, BBHA, CCV Mod, SS HPX, DP-Tuner, BTS-VB, lots of LEDs, and more... My Truck Pics
..........Just throw it away and get a pack of Napa Circular Linkage clips (part number 7352640) for a couple bucks.
Great info ryan. I was happy when I got mine off without loosing it when installing the WW. Unfortunately it went flying when re-installing but I procured a spare clip from a mechanic at the dealership prior to the WW install after reading all the horror stories about this clip! Think I'll pick up a pack at Napa.
I agree, I'm gonna get some too just for when I crank mine down. Rep points for you Ryan.
__________________
Mike
2001 Auto Crew Cab 4X4. 38R and Swamps Hybrids. Transgo and diode Tranny. 400HP but not really. 05 front end and stickers makes it faster.
