1997 Explorer 4x4 V8 Check engine P0420 - Ford Truck Enthusiasts Forums
Old 06-01-2006, 11:14 AM
00GT's Avatar
00GT 00GT is offline
00GT is starting off with a positive reputation.
My grandparents check engine light came on in the 1997 Explorer. It has the 5.0, 4x4, auto. Took it to autozone and code P0420 came up.
Any ideas what could be the problem?
Old 06-01-2006, 04:28 PM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
P0420 is "Cat convertor efficiency below threshold bank one" which is passenger side.
Since thats the only code that came up the cat most likely needs to be replaced.
Best thing to do is take it to a GOOD independant shop & have it checked out.
BTW, it looks like this is past the 8 year/80K federal emmisions warranty, but maybe not.
If the truck is less than 8 years old & has less than 80K miles, check with your Ford dealer. Might get a free replacement cat.
Old 06-01-2006, 07:42 PM
Looks like there is a TSB on the PO430/0420. Check out the post from projectsho89 in the thread "97 Mercury Mountaineer PO430 emissions error."
Old 06-03-2006, 09:23 AM
gman88's Avatar
gman88 gman88 is offline
gman88 is starting off with a positive reputation.
Check out this thread http://www.ford-trucks.com/forums/sh...d.php?t=440835
For some reason everyone is quick to think that the cat is bad, others think that replacing the downstream (after cat) O2 sensors will help, it won't. I replaced the upstream sensors (before cat) and the code and light were gone after a few driving cycles, it has been code free for two months now.
Good luck
p0420 and bad fuel milage maxtruck00 Explorer, Sport Trac, Mountaineer & Aviator 0 01-26-2016 05:47 PM
P0420 code ???? StewB 1999 to 2016 Super Duty 5 05-31-2015 08:11 PM
'96 4.9L with P0141 & P0136, Replaced O2, now P0420 warren561 1987 - 1996 F150 & Larger F-Series Trucks 0 08-18-2014 08:33 PM
P0420 & P0430 codes cottrellp 2004 - 2008 F150 4 06-13-2010 06:21 PM
BOTH P0420 AND P0430 CODES prochamp 1999 to 2016 Super Duty 9 04-18-2010 03:12 PM
Tags
1997, 2003, 97, check, code, engine, error, explorer, exploroecode, f150, ford, light, mercury, mountaineer, p0420, po420, po430, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
