What kind of HP/ft-lbs does the 6.4L spec at??
#46
#49
#50
#51
#52
Originally Posted by mattsf250
ahh, but how can they keep the egt from melting everything pulling a 15k trailer up an 8% grade with the drivers foot on the floorboard?
Maybe too much info for the average Diesel owner though.
#53
I am amazed at how many apparently didn't bother to read the 14 page presentation from International on the new 6.4L PowerStroke. Here is page 11 of the 14 page document.:
oil drain was 7,500 for 6.0L
fuel filter was 15,000 for 6.0L
from page 3:
Engine
Highlights
6.4L Power Stroke Diesel
• 350HP and 650 lbs.ft.
• Two turbochargers in series,
one fixed low pressure turbo
feeding a variable turbine high pressure turbo
• High Pressure Common Rail
(HPCR) Injection System with
multi-shot capability
• 10,000 mile oil drain interval
• 20,000 mile fuel filter change
interval
Highlights
interval
from page 3:
• Improved Turbocharger System
– Dual turbocharger, one using EVRT®
– Improved transient response for increased performance feel
– Ability to maintain power at high elevations
• Improved Fuel Injection System
– High-pressure common rail featuring the Piezo Actuation Technology
– Quicker response for better acceleration
#54
on
The info is approx. 1.5 years old and many changes could have occurred since then...so I wouldn't take anything to the bank on this except basic hard design criteria. Sequential Turbo's etc....
Example: it will be interesting to see if Ford subscribes to things like the 10,000 mile oil change.
#55
wow, so its a smaller turbo feeding the bigger turbo, but the bigger turbo is still a VVT? if im thinking right, then we could see HUGE increases from aftermarket tuners. the only reason i can come up with for them keeping the bigger turbo VVT is so it can make 350hp and 650lb-ft torque at see level, and then keep making 350/650 at high altitude by changing the vanes on the VVT so it produces more boost since the air isnt as dense. does that make sense at all?
#56
#59
Originally Posted by pstrang
Where's your source?
Before I purchased by truck, I did the study in 2004/5 and here are the results (I haven't researched 2006 numbers). Source: HyperPac dyno charts for auto trannies and 3.73 rear ends (stock numbers), except the cummings was from Edge Products dyno charts for the 5.9L 600 series CTD (stock).
Claimed Dyno %
gm 310/565 236/413 76%/73%
ford 325/570 296/473 91%/83%
dge 325/610 260/430 80%/70% (source Edge Products 600 series)
This helped me make my decision. Ford is all over the others. GM has the biggest loss!
Claimed Dyno %
Food for thought.................. all of the new diesels can be chipped/tuned to make big hp. What would really make ford shine was if the tranny could actually hold up reliably to a tune that makes 500rwhp.
#60
No matter how you look at it, 500rwhp would need an aftermarket tranny for any of the big three.
