Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-31-2006, 03:32 AM
ford88ranger ford88ranger is offline
Garage is empty, add now
ford88ranger is starting off with a positive reputation.
Timing pointer for 2.3L
Im new to these engines. Is there an aftermarket source for a bolt on timing pointer for the 2.3L engine. I have one all apart at the moment and I would like to get rid of the plastic timing belt cover if possible. I understand I would most likely need a couple seperate pointers, one for the crank and one for the cam, and possibly a third one for the intermediate shaft. Any info would be great. Thanks in advance...
  #2 (permalink)
Old 06-01-2006, 08:09 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
Hi and Welcome to FTE! Please take a moment to check out the Guidelines, they contain important info you'll need when posting on the site:
http://www.ford-trucks.com/guidelines.html
For a good source of aftermarket parts for the 2.3, look to Esslinger engineering or Racer Walsh. These guys race these engines extensively and have for years, and bothe have tones of interesting (and expensive!) stuff for them. Since racers usually remove the timing cover it occurs to me that they might have such a thing as you're looking for.
http://www.esslingeracing.com/
http://racerwalsh.zoovy.com/
On Edit:
Esslinger has what they call a Power Pulley which is simply a lightweight pulley that's degree'd all the way around and you can fabricate your own pointer fairly easily to work with it. I don't see anything on the Racer Walsh site, but I didn't really look around at great length.
You can easily fabricate a pointer from a piece of heavy gauge wire (like a coat hanger). Just a little bending, a loop in one end to bolt it to a convenient mount for the timing cover and a bit of tweaking to get it lined up with the 0º mark and you're there! That's how we used to make them for our mini-stocks.
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 06-01-2006, 03:23 PM
Thanks, I knew about esslinger but they did not have anything that I was interested. Ok I lied, but nothing for this build. Ill check out the other site. I appreciate the effort... David F.
  #4 (permalink)
Old 06-03-2006, 03:13 PM
jamnjm jamnjm is offline
jamnjm is starting off with a positive reputation.
It all depends if this is for the street with the alt. and power steering pumps too.
www.powerbyace.com has a couple in the works and you might want to check out their new TVL checker too!
  #5 (permalink)
Old 06-03-2006, 04:34 PM
westtntrucker's Avatar
westtntrucker westtntrucker is offline
westtntrucker has a very good reputation on FTE.westtntrucker has a very good reputation on FTE.westtntrucker has a very good reputation on FTE.
http://www.raceeng.com/domesticcatalog-lowres.pdf
Look on page 12
  #6 (permalink)
Old 06-03-2006, 05:13 PM
Thanks again guys...David F.
  #7 (permalink)
Old 06-03-2006, 06:12 PM
FYI....you don't need a full degree power pulley as every pointer points to a different place on them.
What you need is to get your pointer, set TDC and then mark the pulley properly.
It seems most mount over on the pass. side but the dist. is easier to reach from the driver side......
Tags
23, 23l, check, cover, degree, esslinger, find, ford, intermediate, marks, pointer, shaft, time, timing, timming, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
