Front end alignment
There used to be a place where Coffee ran into Scenic, called Scenic Wheel and Brake...it's gone now, but I'm pretty sure when they moved, they either kept the same name, or mentioned "formerly Scenic Wheel and Brake", they used to do my staright axle trucks way back in the day.
If no luck fnding them now, call Neville Brothers, Larry used to be into 40's and 50's Chevy PU's, and could probably steer you (pun intended) in the right direction.
ALedbetter1
02-28-2014 02:06 PM
