1975 grumman step van vacuum problems
Old 05-27-2006, 06:54 PM
sausrigging's Avatar
sausrigging
sausrigging is offline
I have searched endlessly looking for vacuum diagrams for my stepvan with a 4.9 I six. What i have is a vacuum line of what looks to be a check valve? The line is not connected to anything at the moment.
I have a photo of the line and fitting, maybe one of you kind folkes can tell me what it is and where it goes..
thanks
http://i81.photobucket.com/albums/j222/qcyacht/3.jpg
Old 05-27-2006, 07:01 PM
sausrigging
another photo
Here is a shot of the fitting itself.
http://i81.photobucket.com/albums/j2...acht/valve.jpg
Old 05-27-2006, 08:27 PM
sausrigging
http://i81.photobucket.com/albums/j2...iffdaff003.jpg
Heres a shot of the van.
Old 05-28-2006, 12:08 PM
sausrigging
This forum is not all that active..
Old 05-28-2006, 04:40 PM
kotzy's Avatar
kotzy
kotzy is offline
I think thats a Grumman body on your Ford chassis, I think it should have a
Hyrovac Brake booster on it and that may be where that rubber line went.
they had a 5/8 rubber line as a supply hose with a check valve between
the booster and the engine. They also had a vent hose with a filter
on the opposite side of the housing. If the engine would fail to idle it was caused
by the diaprahm in the booster failing they sometimes would draw brake
fluid out of the master cylinder as well. Unit was mounted on the frame
near the transmission with to brake lines going to it. Perhaps someone
had problems and removed it and left the lines. even with drum brakes
I don't think this P 400 or 500 would stop to well without it. My thoughts.
Old 05-28-2006, 04:46 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Please use links for pictures.
Your cooperation will be appreciated by the other users.
xjcamaro89
2004 - 2008 F150
447
01-31-2022 07:35 AM
Necronommicon
1999 to 2016 Super Duty
06-08-2017 02:52 PM
chesster51
08-01-2016 08:30 PM
grandpas1974
04-08-2016 11:34 AM
Wellcraft270
04-07-2007 03:51 PM
Quick Reply: 1975 grumman step van vacuum problems
