Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-27-2006, 04:10 AM
Hellbore Hellbore is offline
Garage is empty, add now
Hellbore is starting off with a positive reputation.
Erratic tachometer reading?
I have an Actron "auto troubleshooter" that cost me like 60 bucks at AutoPWN.
Unfortunately, the RPM measurement jumps around a lot. Any ideas why this would be?
My Duraspark module is new, dizzy rotor and cap are new, plugs are new, plug wires are new.
Engine is a rebuilt 360, sounds like it is idling very nicely but the tachometer reading jumps all over the place.
Tach is connected as the manual says to connect it.
I'm puzzled... the multimeter seems to work fine besides the RPM measurement...
  #2 (permalink)
Old 05-27-2006, 09:21 AM
Putt's Avatar
Putt Putt is offline
Putt is starting off with a positive reputation.
Is it the inductive type pickup(wraps around a plug wire)? It may be that the sensor wire is too close to other plug wires or the coil wire and it is picking up more than one signal. The same thing can happen with the factory tach if the wire is too close to the plug wires.
__________________
Putt
1966 F100 4X2 428 4 and 3 sp. 2.75:1 rear
1989 F250 Super cab 351 4X4
  #3 (permalink)
Old 05-27-2006, 01:58 PM
It is the type of tach that connects one lead to the negative coil terminal, and one lead to ground.
I'll try moving spark plug wires away and see if that helps thanks.
  #4 (permalink)
Old 05-30-2006, 03:18 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain has a good reputation on FTE.Freightrain has a good reputation on FTE.
Sounds like poor connection. It just takes the pulse signal from coil and creates a reading from it. If the coil or ground connection is at all loose it will create intermittent loss of signal thus causing erratic needle movement. Ya, sounds simple huh? LOL!!!
Make sure connections are tight, and when needle is jumping around, wiggle wires to see if that makes it better or worse.
Only the "inductive" type would be erractic if around other wires. This would be the clamp on style using the spark plug wire.
__________________
*signature delete option*
  #5 (permalink)
Old 05-30-2006, 04:10 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Try it on another vehicle and see if it still does it ...
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see. ®
  #6 (permalink)
Old 05-30-2006, 04:16 PM
Hey, I think I figured out what was causing it... It is a multimeter-type tach, and so far I had only used it while my timing light was hooked up. Well, that damn timing light must be a doozy because the tach works perfect when the timing light isn't connected.
I also noticed, by connecting and disconnecting the timing light while the engine was running, that when I connect the timing light to spark plug #1 wire, the engine actually runs worse! Crazy huh? Why would that happen? Does the timing light somehow rob some of the engine's spark?
  #7 (permalink)
Old 05-30-2006, 04:53 PM
Krewat's Avatar
I take it your timing light has to be hooked in inline with the wire and plug? Your timing light might have a problem, as in, it's sparking internally.
The "engine running worse" is because #1 is misfiring
__________________
  #8 (permalink)
Old 05-30-2006, 04:55 PM
Well it's funny you mention that, I do think the light was sparking internally because when it was turned off (trigger not pushed) it was making a ticking noise inside.
Would that internal sparking cause the cylinder to misfire or does a timing light always make it misfire?
  #9 (permalink)
Old 05-31-2006, 12:43 PM
Shiftoholic
Depends on the type of timing light. The clamp on style WON'T create problems.
The other variation, that makes you insert it between the plug and the plug wire MIGHT create issues.
__________________
Tags
auto, coil, engine, erratic, f150, incorrect, induction, inductive, iradic, misfire, reading, readings, tach, tachometer, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
