Torque converter drain plug
Old 05-26-2006, 08:04 PM
Glock's Avatar
Glock
Glock is offline
2001 F150 4x4 SuperCab Off Road XLT, 139” WB Style sides, 5.4L, 4R70W, 3.55LS, 6500 GVWR
What is the Ford part number for the torque converter drain plug? The local Ford dealer part shop said you can not order it unless you order the torque converter. I thought it was a one time uses drain plug and I reused it once all ready.
Old 05-26-2006, 09:28 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
i just put thread sealant on it and reuse it.
Old 05-26-2006, 11:17 PM
HomerWinzlow's Avatar
HomerWinzlow
HomerWinzlow is offline
Yep, someone was misinforming you on it being a single use plug. Otherwise you get a service and then next service you buy a torque convertor? LOL Nope. At least you have a model that still has one.
Old 05-27-2006, 10:48 AM
qdude79's Avatar
qdude79
qdude79 is offline
Naw, use it. If you're worried, run it for a bit, get under the truck and pull the dust cover off your bellhousing and check for leaks. Don't think you'll find anything if you do it right.
Qdude
Old 05-28-2006, 09:57 AM
BlueOvalFitter's Avatar
BlueOvalFitter
BlueOvalFitter is offline
I've been a pipefitter by trade for over 23 years now,and in that time i've never seen a plug that cannot be re-used,unless it were stripped or cross threaded.Use it until the end of time!
r___r
1999 to 2016 Super Duty
12-15-2013 06:11 PM
hav24wheel
03-06-2013 01:44 AM
05ExcursionLTD
06-19-2009 07:15 AM
Mustangoutcast
01-15-2008 12:06 PM
redneckboy
02-19-2007 10:17 PM
Quick Reply: Torque converter drain plug
