Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 05-26-2006, 02:42 PM
Snowking's Avatar
Snowking Snowking is offline
Snowking has a good reputation on FTE. Snowking has a good reputation on FTE.
292 assemble
Just brought my 292 home from a rebuild. I have to put the heads, rocker, carb. on.
Any tips?
Thanks
Ryan
__________________
2001 Ford F250/ V10 4x4 1969 Ford F100/ 300
1967 Ford F100/ 352 4spd 1957 Ford F250/ 292
1952 Ford F1/flathead 1950 Mercury M135
1949 Mercury M47 1947 Mercury half ton
  #2 (permalink)
Old 05-26-2006, 04:00 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
Make sure threads for the head bolts in the block are clean by running a tap down each hole. Dont use sealer on head bolts (I did once and it was bad news). On head gaskets the square corner should face the front of the motor, and be on the intake side. Sealer on intake gasket? Someone please say yes or no to that one.
__________________
1946 1/2 ton with Y-block
1962 Unibody F-100
1990 Ranger 4WD
1954 Model 600 tractor
  #3 (permalink)
Old 05-26-2006, 10:15 PM
Homespun91's Avatar
Homespun91 Homespun91 is offline
Homespun91 is starting off with a positive reputation.
Depending on the gasket type & the manifold "fit" to the block & heads, as a general rule, no. I will occasionally use something around water passages. Some guys will use white grease on the manifold side of the gaskets if they plan to do a lot of manifold swaps/changes. My view is that a good fit & correct torque will do more to seal it than goop ever will. Some gaskets like the blue Felpros don't work very well with sealer. My personal preference are the Mr. Gasket Ultra Seal sets (naturally, not available for a Y), though I detest any other Mr. Gasket product ever made.
Ryan, am I correct in assuming that the short block is already assembled by the machine shop? Check the timing chain & gears to verify they are correct, & not set up like most other engines. If you aren't sure what I mean, look at the new t-chain thread in this forum.
Also, take some time to check all the freeze & other plugs to confirm they are in place & correctly installed. It completely sucks to do a two minute/$1.00 procedure once the engine is already in the chassis. On those same lines, make sure the oil pan bolts aren't overtightened. Don't overtorque the valley cover, either. I'd spend some time making sure it's not bent.
Lash the rockers before you fire it, & check them all over again once the cam is broken in. Hopefully the machine shop used moly cam sauce on it, but I'd go to the local GM parts dept., get a bottle of EOS, paint the rocker shafts, rocker tips, pushrod ends, valve tips, & distributor gear with it, then dump the rest of the bottle over the cam lobes before you seal it up. I'd use 15W-40 Shell Rotella to break it in, or if you want to spend more $$$, Valvoline (or whoever) Racing oil, to get the ZDDP content.
Fill the carb bowl before you start it. There's a saying to the effect of "The ONLY used parts that should ever go back into an engine are a KNOWN GOOD distributor & carburetor", and it makes a good point. Keep a garden hose handy as well to put out fires (hopefully not) & mist the radiator to cool it down. An ABC-rated extinguisher is a good thought too...
Good luck!
__________________
IN: Staring adversity in the face while working on your car and coming out on top
OUT: Finally realizing that every $%&# thing you touch on your car turns to adversity
  #4 (permalink)
Old 06-15-2006, 05:41 PM
toolebox1 toolebox1 is offline
toolebox1 is starting off with a positive reputation.
Go to this website http://www.ford-y-block.com/assemblyerrors.htm trust me this is good!!!!!!!!!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
