Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-26-2006, 11:18 AM
troy1059 troy1059 is offline
Garage is empty, add now
troy1059 is starting off with a positive reputation.
Another WVO question
Greasel.com sells a unit called the nomad. It appears one can just pull up to the old grease pit and pump wvo into the tank and drive off. The system seems to be fairly complete. I was curious if any of you have seen or heard about this system, any good points or bad points and if it is a good system does anyone make something comparable. At least with this, one doesn't have to gather the wvo and filter it at home before using it.
  #2 (permalink)
Old 05-26-2006, 05:30 PM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
I haven't used this product. But have read the info on the site.
Here is my opinion.
Point 1
Racor Aquabloc filters only block free water not suspended or emulsified. In #2 I believe you can't get emulsified or suspended water so these would work great for #2
Point 2
They never even suggest you test the fuel for suspended or emulsified water. I never put fuel in my tank unless I do a frying pan test on the oil.
Ther eis really no substitute for well settled dewatered oil. The best way to do that is through time and heat.
If I were going to use soemthing like this I would never go down very far in a drum or dumpster. I would never pump straight into the tank I feed my engine with and I would test for water.
Plus a 12 volt gear pump is about $125. A filter can't but maybe $300. SO you could build this yourself for less then $500 bucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
