Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-25-2006, 09:46 PM
bbf150 bbf150 is online now
Garage is empty, add now
bbf150 is starting off with a positive reputation.
certain brands get better mileage?
i've owned this truck for almost 2 yrs and put 25,000 miles on it-'77 f150 2wd 400 performer intake,holley 600dp carb,c-6 with 2.75 gear-usually run marathon and shell gas but filled up with sunoco and mileage is never over 12mpg no matter what-well got 14.4mpg around town,couldn't believe it-anyone else ever experience this
  #2 (permalink)
Old 05-25-2006, 10:29 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
It can happen. Keep using the Sunoco!
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #3 (permalink)
Old 05-26-2006, 10:57 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
I may have less ethanol in it than the other brands. Here in CA, brand makes absolutely no difference because the formula is so highly regulated.
Jim
  #4 (permalink)
Old 06-04-2006, 01:50 AM
bigjohn1985 bigjohn1985 is offline
bigjohn1985 is starting off with a positive reputation.
there s somthing the gas companeys are hiding from you and me
1ethanol helps mpg
2 unless u live in the city u may not be getting the brand u want or think ur getting
3 if u get gas when there filling there tanks u get the dirt from the bottomof there tanks
4 and they use water to daloot the gas
  #5 (permalink)
Old 06-04-2006, 05:18 AM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
Quote:
1 ethanol helps mpg
Nope. Ethanol is there to help with emission. If anything, it will slightly decrease mpg since it has less energy than gasoline.
Assuming "daloot" neans 'dilute', this is utter non-sense.
  #6 (permalink)
Old 06-04-2006, 08:59 AM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
I think what he means in #4 is the gas is separated in the pipeline between loads by water. The pipe line must pump a certain amount of the fuel at the end of a load and the beginning of the next load into what is called a slush tank. This fuel contains the water that separated the loads.
Un branded stations and station owners that are crooks by this fuel from the slush tank and a cheaper price and sell it. This fuel also lacks all aditives that the name brand station would add at the bulk plant before taking it to the station.
I personally always buy my gas from a reputable name brand station to avoid getting this slush tank gas. I get the best mpg from BP Amoco in my Fords.
Dan
  #7 (permalink)
Old 06-04-2006, 02:43 PM
Gasoline and water doesn't mix, so if you mix them, they'll separate. Alas, this isn't fully true for blends with ethanol, but it's still not something you can just mix with water.
  #8 (permalink)
Old 06-04-2006, 03:56 PM
Not sure if we are on the same page?
They do not mix water with the gas. The water is in the same holding (Slush)tank as the gas and that gets pumped into your gas tank. Not good, and yes ethanol will absorb water.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
