Any problems with BD in 6.0's? - Ford Truck Enthusiasts Forums
Old 05-25-2006, 08:55 PM
B846B B846B is offline
B846B is starting off with a positive reputation.
I am seriously considering running BD in my 2004 6.0 Excursion, but have a few reservations. I have read in several different websites about International not recommending anything over b5. I assume that several of you run b100 in similar motors and year vehicles. Has anyone had any problems with running BD in their newer 6.0's? Is there anything in the 6.0 that may fail as a result of running b100? Some sites that I have read state that b100 is corrosive and can cause seals, gaskets, plastic parts, etc. to fail. Then of course Ford would void my extended warranty that I paid a hefty price for. I know that the filters would have to be changed more frequently, but besides that are there any other issues I should consider? I live in southern Nevada and will be looking into making the BD at home as I do not know of any place that sells it here yet. Any one is southern Nevada have any problems obtaining used oil?
Thanks for everyones input in advance!
Old 05-28-2006, 01:49 PM
Motown Fire's Avatar
Motown Fire Motown Fire is offline
Motown Fire is starting off with a positive reputation.
I have run B99 for about 5,000 miles is my truck with no problems. Idles more quiet and sounds different at startup. Truck runs really well on it.
Old 05-29-2006, 07:52 PM
Any problems with hoses, seals, plugs, going bad? I really want to switch to BD but am still a little leary. I have spent a lot of money on my main mode of transportation, don't want it to go bad as a result of using the fuel.
Old 05-29-2006, 09:10 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant future
Fords stand is B5 only of approved biodiesel. Go to www.biodiesel.org for fuel specs and where to purchase fuel. I have used it in all my farm equipment and on my ford diesels for years. I hate to waste a warranty because of fuel.
Old 05-30-2006, 07:49 AM
bhiggins bhiggins is offline
bhiggins is starting off with a positive reputation.
B846B,
I don't think you'll have problems with the hoses and seals and such. Every thing since about 94 has made the switch to synthetic rubber
what i would concern myself with trying to find out is whether or not the fuel will polymerize (sp?) under the new higher injection pressures the 6.0 runs
i don't know but have heard this is the main concern.
Higgins
Old 06-13-2006, 03:30 AM
kennedyford's Avatar
kennedyford kennedyford is offline
kennedyford is starting off with a positive reputation.
You wont have any probs, the information on corrosive was the use of waste veggie oil specifically linseed. Bio will super lube those injectors and hopefully keep you from replacing them. I know one guy with 180k and 19 injectors on dino. He is taking my suggestion and putting an oil bypass. If you switch to 100 you will have no probs, more power, less noise, more torque, and longer lasting oil. That is the prob with dino is the emmission req.ments and crystalizing carbon in the injectors and turbos during reburn. Bio is ment to be in the 6.0 and then they wouldnt have as much probs.
Old 06-15-2006, 12:00 AM
dieselboy427 dieselboy427 is offline
dieselboy427 is starting off with a positive reputation.
DON'T DO IT, It'll take the sealant/laquer off of the inside of the tank, plug the fuel lines and filters.
Old 06-15-2006, 01:00 AM
BLK94F150 BLK94F150 is offline
BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.
Quote:
That's just crap build up from the dino diesel being disolved by the biodiesel. After you change the filter a couple of times, everything will be kosher
Mike
Old 06-15-2006, 01:31 AM
The tanks I've seen pulled rust after fuel is removed. (Tanks removed to diag fuel filter plugging) This isn't only in ford PSD pickups. It happens in industrial, farm, over-the-road, and all other mfrs using steel tanks.
Old 06-15-2006, 05:28 AM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
I'm pretty sure the tanks on the 6.0 are plastic. At least the 28 gallon one I have is. It has some metel plates around it to protect it from road hazards.
Old 06-17-2006, 12:15 PM
namrehs300 namrehs300 is offline
namrehs300 is starting off with a positive reputation.
I've been running B20 on and off for a few months now in my 05 PSD. BioWillie. Only difference I notice is that the idle is a little quieter. But from what I can tell, I seem to get just a little less mpg's - like a half to one mpg.
I like the idea that BD does a better job of lubrication. If I don't run B20, then I run regular with DieselKleen additive. That may account for the slightly better mileage with regular - maybe my cetane is higher with regular and the additive than it is with B20 alone?
I've had one fuel filter change since running BD and didn't really notice that they were any dirtier than before. I change every 15,000 miles.
Old 06-17-2006, 08:36 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Every Superduty/Excursion from 99-present has plastic tanks. The exceptions would be the cab & chassis trucks with custom tanks.
Bio Diesel in a 6.0L? 6.0superduty Bio-diesel, Propane & Alternative Diesel Engine Fuels 4 01-12-2016 03:01 PM
shop recommendations mxer0022 Nevada Chapter 2 10-26-2014 06:06 PM
1995 OBS 1211 code on hard acceleration txoutlaw1 1994.5 - 1997 7.3L Power Stroke Diesel 6 01-07-2013 01:05 AM
1211 and 1212 codes countrycar 1999 - 2003 7.3L Power Stroke Diesel 8 11-21-2012 08:16 PM
What is considered "overheating" 993/4ton Modular V10 (6.8l) 19 08-18-2007 01:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
