Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-25-2006, 10:33 AM
amartin98 amartin98 is offline
Garage is empty, add now
amartin98 is starting off with a positive reputation.
Oil Dipstick location
Hello everyone. Let me thank you in advance for any help you can provide....
I just recently did a swap from a 300 to a 351M. The engine that I used I beieve may have been from a car. Anyhow, I also had an old 351 M from a truck, so I used the mounts, oil pan and everything from that engine, on the new engine to make it work.
Well yesterday I went to put the oil dipstick in the block, right next to the front plate behind the alt. and I found that the hole was filled. It was not a screw in plug or anything, alomst looks like it was never drilled out. I put a punch in there and hit a few times with a hammer, gently of course, and nothing happened. This engine came with the dipstick in the oil pan, so now I am not sure what to do. I am feeling kind of like a dipstick. ha ha ha....anyhow.
Does anyone have a suggestion, or some ideas about what to do.
Thanks again
  #2 (permalink)
Old 05-25-2006, 10:57 AM
53fatfndr's Avatar
53fatfndr 53fatfndr is offline
53fatfndr is gaining momentum as a positive member of FTE.53fatfndr is gaining momentum as a positive member of FTE.
If you have a rear sump pan, you want the dipstick in the rear of the pan. If you have a front sump pan, you want the dipstick to go through the front of the block. Good luck
__________________
Branden
'53 Ford F-100 Hot Rod
'79 F-350 4X4
'94 F-150 4X4
http://www.ford-trucks.com/user_gall...163821.520.390
  #3 (permalink)
Old 05-25-2006, 10:59 AM
fastford59's Avatar
fastford59 fastford59 is offline
fastford59 is starting off with a positive reputation.
I'm thinking your engine is a Windsor,with the dipstick in the oil pan...FF59
__________________
if it ain't FAST,if it ain't FORD, it ain't in my yard...FF59
  #4 (permalink)
Old 05-25-2006, 11:29 AM
lol, I am certain that it is a 351M. When I got this motor it was a rear sump oil pan, and pickup (actually it was more in the middle), I used the front sump pick and pan off of my other 351M.I know that the dipstick is supposed to go in at the fron't of the block, but the hole where the Dip Stick is supposed to go, is not drilled out.....At least it does not look like it, or feel like it.......??????????
Lol, as long as it is just the simple things that go haywire.....
Thanks again for your input...
Andrew
  #5 (permalink)
Old 05-25-2006, 12:39 PM
53fatfndr's Avatar
I have no idea what you have now, as I have never seen or heard of a middle sump pan on a 335 series engine...
__________________
Branden
'79 F-350 4X4
'94 F-150 4X4
  #6 (permalink)
Old 05-25-2006, 09:59 PM
husker's Avatar
husker husker is offline
husker has a great reputation on FTE.husker has a great reputation on FTE.husker has a great reputation on FTE.husker has a great reputation on FTE.husker has a great reputation on FTE.
I have 3- 400's here at present. One is in my 78 Bronco and it has the dipstick on the driver's side going into the middle back of the pan to a rear sump. The engine that came out of the Bronco was the same. I also have a '71 400 that came out of a car and it has the dipstick on the front of the engine on the passenger side in the location you describe. That engine was rebuilt and has a truck rear sump pan on it and the hole for the dipstick in the pan is blocked off. The PO of the engine did that.
It seems the 351m/400's from autos used the front location and the trucks the side location for the dip stick.
__________________
Del
Kansas Chapter Geezer
2001 F250 SD PSD 4x4
78 Bronco
54 F250
64 Thunderbird
  #7 (permalink)
Old 05-26-2006, 12:12 AM
sparky69's Avatar
sparky69 sparky69 is offline
sparky69 is starting off with a positive reputation.
i think that the rear sump pans were only used on 4x4 trucks. cars and 2wd trucks got front sump pans and had the dipsticks going into the block. why not just get the dipstick for the rear sump pan? is the hole in the pan welded closed?
  #8 (permalink)
Old 07-03-2006, 02:20 PM
mgraveman mgraveman is offline
mgraveman is gaining momentum as a positive member of FTE.
He would have to pull the engine to put a new oil pan on it.
I just found I have the opposite problem - two holes....
Mines a 2wd F350, has dipstick in pan (now one in the block too)
__________________
2001 Excursion 4x4 - V10
1994 F350 Reg Cab Dually PSD/ZF5 2wd
1996 Town Car
1996 Mustang GT
  #9 (permalink)
Old 07-03-2006, 03:24 PM
husker's Avatar
I would probably just use the location that is appropriate and plug the other hole, unless you want to confuse the innocents and use two dip sticks. lol
__________________
Del
78 Bronco
54 F250
64 Thunderbird
  #10 (permalink)
Old 07-03-2006, 04:54 PM
bmc69 bmc69 is offline
bmc69 is starting off with a positive reputation.
[quote=amartin98Well yesterday I went to put the oil dipstick in the block, right next to the front plate behind the alt. and I found that the hole was filled. It was not a screw in plug or anything, alomst looks like it was never drilled out. I put a punch in there and hit a few times with a hammer, gently of course, and nothing happened. [/QUOTE]
The plug only punches out from the bottom...as far asI know. 50 or so blocks through here and I've never seen one that was not drilled out..but with Ford anything is possible. When I stick the 400s in EBs I use the front block (pass car/pass side front) dipstick hole that you are referring to.
Tags
2001, 351, 351m, 64, block, dip, dipstick, drivers, f150, f350, ford, hole, location, oil, put, side, stick, tbird, winsor, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
