Techron Solved the problem - Page 2 - Ford Truck Enthusiasts Forums
Old 06-30-2014, 02:15 PM
Clay H's Avatar
Clay H Clay H is offline
Clay H has a very good reputation on FTE.Clay H has a very good reputation on FTE.Clay H has a very good reputation on FTE.
Thanks for the replies, I'll try so DK as well.
Old 06-30-2014, 02:17 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Techron from 8 years ago is likely a lot different than the Techron available today, just saying.
Josh
PS: When I saw the thread title I thought this was going to be about DieselTechRon...
Old 06-30-2014, 02:22 PM
spdmpo's Avatar
spdmpo spdmpo is offline
spdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to behold
Well here's the thing. At the time my fuel gauge started sticking I had never used any diesel additive in the truck. I don't believe the PO ever did either. I put in a normal dose of 1 oz/3 gal with no results for the first tank. The 2nd tank I did a 3oz/3gal ratio and it began working correctly again, but a couple times it intermittently flaked out on me. So a did a 3rd tank of 3oz/3gal ratio and it went away completely. Now sometimes I use DK, sometimes I don't (because it stinks and it spilled in my toolbox which has made everything still reek like DK so now I just keep it at home) but the issue has never come back.
Seeing as how you use it regularly I couldn't guess as to if this would work for you or not.
Old 06-30-2014, 03:03 PM
diesel_dan's Avatar
diesel_dan diesel_dan is offline
diesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to behold
Quote:
Josh
That's funny: shortening his name...
I doubt the product has changed, but I think they have cut down on the choices. I knew one of the developers (Chemical Physicist) of Techron but have lost contact with him some years back (we are both Chevron retirees but also raced Porsches together). On Edit: I meant to say it's more likely there have been some bad outcomes -- I noticed over the years how the product info originally said ok for diesels (even Ford had that TSB) then it went to only non-direct injection and now: don't use it in any diesel...
I know it also is an Octane booster, but I don't recall if that was the carrier or the PEA formula itself. It has performed miracles in some of my gas powered stuff!
I still might try it in the Bobcat, but I think I'll give spdmpo's overdose of DK a try 1st. Damn Bobcat has this LOUD alarm every time the gauge bounces low (I've thought about clipping the alarm wires, but it's the monitor for everything else too).
spdmpo: thanks for the recipe!
Old 06-30-2014, 03:31 PM
spdmpo's Avatar
No problem, good luck. I guess I should have commonized it and just said 1oz/1gal, hahaha.
Old 06-30-2014, 04:00 PM
Bullitt390's Avatar
Sounds like it would just be easier to run a tank of B20...
Josh
Old 06-30-2014, 04:07 PM
diesel_dan's Avatar
Josh
If one could find that in my area it'd also be worth a try I do have a station that has off-road diesel not far from here -- saves a few coins, but I don't think there is any difference other than the dye and less taxes (I think all of CA is ULSD...).
Maybe I'll go hit some Bobcat or Kubota forums and see what they say...
Old 06-30-2014, 04:14 PM
Bullitt390's Avatar
All Diesel, whether dyed red, green or yellow is ULSD.
B20 is good stuff and cleans out everything.
Josh
Old 06-30-2014, 04:57 PM
spdmpo's Avatar
Josh
That would be a good option also, I don't have any of that around here. I have to go 8 hours to TN to get that.
However, last time I filled up my 7.3 with B20 my fuel pump died 5 miles down the road. It was full of crud and locked up. I do not believe it to be coincidence. It cleaned my tank and filler lines I guess. I ended up replacing the pump and adding a filter in front of the pump. I won't be using B20 again in this truck. It'd be nice to start out from new though.
Old 06-30-2014, 05:52 PM
diesel_dan's Avatar
Just as a follow-up, I started researching diesel fuel additives with PEA (which is the main cleaning agent in Techron). I kept seeing that Chevron used to make diesel versions of Techron under it's Delo brand -- seem to have disapeared, as has Redline RL 1 (I think that's the name) that also had high concentrations of PEA.
Well guess what? Turns out Archoil makes a diesel fuel system cleaner AR6400-D that has PEA in it.
So where do folks get their Archoil products at (for the best price)? I tried Archoil themselves but the additive is $19.95 and it's $11 shipping...
I'm still flirting with the idea of the Techron Concentrate, but those dang Kubota motors aint cheap or easy to pull (well, for me)...
diesel newbie, 03 f250 fuel gauge inacurate bholicz 6.0L Power Stroke Diesel 23 02-10-2016 10:26 AM
2009 F250 code P0461 Techron works! savagefan 1999 to 2016 Super Duty 6 05-09-2014 05:58 AM
Gas mileage? Jt00 Ranger & B-Series 4 08-11-2012 10:08 PM
Fuel level errors Yahiko 6.0L Power Stroke Diesel 9 05-05-2012 09:57 PM
erratic fuel gauge jucruzpt Explorer, Sport Trac, Mountaineer & Aviator 1 10-19-2005 07:41 AM
Tags
boost, cetane, chevron, cleaner, complete, delo, diesel, escape, ford, fuel, p0463, system, tank, techron, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
