I'm looking for a way to eliminate the door chime when the keys are in the iginition and the door is open. I know there is a way to disable it but I don't want to permanently disable...just sometimes.
A friend found a wiring diagram and installed a toggle switch in the drivers kick panel that basically cuts the power to the chime. His F-150 was a different year than mine and I don't know if the F-150's and F-250 use the same color wiring
I want to do the same thing but need to know which wire that operates the chime. Anyone know which wire or have a wiring diagram for a 2006 F-250.
First, remove three phillips screws and the lower half of the plastic surrounding the steering column just behind the steering wheel. On the right hand side under the ignition key mechanism you will find a black wire that is sort of plugged into it. When a key is inserted this wire goes to ground and activates the buzzer you are referring to. I simply unplugged mine and put some tape on it, then zip tied it out of the way. If you want a switch, cut the wire in the middle and run each side to a toggle so that when the switch is in the on position the two wires are tied together.
That should do the trick.
Hey Mods, this might be a good one for the Tech Folder if its not in there already.
__________________
2004 F250 6.0 AUTO CC SB SRW LARIAT/FX4
2006 F450 6.0 AUTO CC Chariot Custom (work)
2007 F350 6.0 AUTO CC LB SRW XLT/FX4 (work)
2007 F650 5.9/Allison (work)
I will forward this to Admin.
Thanks kb1aah
__________________ "There is a fine line between fishing... and just standing on the shore looking like an idiot"
How about a work around for the seat belt noise maker when you are sitting in the truck without a seatbelt? That really drives me crazy. I work out of my truck and it really gets annoying while trying to speak on the phone and that thing goes off every 30 seconds.
06 F250 KR...
Thanks!
You can just do the sequence thing in the owners manual to turn that off all together. I forget what it is but there is a instruction in there to turn it off.
I did the seatbelt sequnice on my 06 per the owners manual and it did'nt work .After trying it about 10 times i got aggrivated. On the next try when it tells you to buckle and unbuckle the last time I just kept doing it until the seat belt light flashed. It has'nt gone off sence. Also I disconected the door chime today, Thanks for the tip
