VIN plate engraving/stamping help needed - Ford Truck Enthusiasts Forums
Old 05-22-2006, 06:41 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
I just noticed that my firewall VIN plate is missing. I don't remember even if I had this plate when I bought the truck a few years ago. The truck was also missing the data plate from the glove box.
I just bought a firewall VIN plate from Sac Vintage Ford and need to know who can engrave/stamp it for me. I have the title to my truck and could prove the VIN is legit. I called Sac Vintage Ford and they only stamp VIN plates for '53 and up vehicles. The guy that does it for them won't do '52 and older. I was told to try different engravers.
Has anyone else ran into the same problem? Anyone know if there's someone who does the stamping? I want it to be as close to original as possible. I do have other firewal VIN plates (from other Panels) to use as reference for the stamping, i.e. font, placement, etc...
Thanks, Ilya
Photo courtesy Sac Vintage Ford.
Old 05-22-2006, 10:25 PM
Blue50F-1's Avatar
Blue50F-1 Blue50F-1 is offline
Blue50F-1 is gaining momentum as a positive member of FTE.
PanelMan-
Any place that does engraving ought to be able to help you out. My Father actually does it, but he does free-hand artistic stuff. What you need is some-one who does computer guided engraving--which is not hard to find. My local HS has a machine that does it, and so do a couple places in the mall, and at least one jeweler I know of. All it takes is having a font that is similar or identicle to that on your other VIN plates. They type up what you need in the computer, stick the plate in their machine, and in less than a minute you're done.
Good luck!
Old 05-22-2006, 10:30 PM
Brian_B's Avatar
Brian_B Brian_B is offline
Brian_B is gaining momentum as a positive member of FTE.
I don't know about VIN plates, but the local place that makes trophies engraves all sorts of things. Medical alert tags, watches/jewelery, door/desk name plates, name badges, etc. Give one of them a call.
Old 05-23-2006, 02:54 PM
Gary E's Avatar
Gary E Gary E is offline
Gary E is gaining momentum as a positive member of FTE.
What about buying a punch kit from HF or something?
Old 05-23-2006, 03:03 PM
John - NNY John - NNY is offline
John - NNY is starting off with a positive reputation.
I think back then, they used steel stamps. Go to a local machine shop and use theirs.
John
NNY
Old 05-23-2006, 03:07 PM
fatfenders56's Avatar
fatfenders56 fatfenders56 is offline
fatfenders56 has a good reputation on FTE.fatfenders56 has a good reputation on FTE.fatfenders56 has a good reputation on FTE.
I think the problem with all of this is that the original plates were stamped from the back side
Old 05-23-2006, 06:09 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is online now
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
Ilya,
You can try this place.
http://www.datatags.com/
I don't know if they will stamp your plate or you will to buy one of theirs but it's worth a try. I have never used them but I have given this link out to a couple of people who thanked me and seemed very happy with the product.
Old 05-23-2006, 06:18 PM
53fatfndr's Avatar
53fatfndr 53fatfndr is offline
53fatfndr is gaining momentum as a positive member of FTE.53fatfndr is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by bobj49f2
Ilya,
I got a quote from them a few weeks ago for my '53. They would supply the plate and stamp it for $85.
Old 05-23-2006, 06:36 PM
51PanelMan's Avatar
Quote:
Thanks, Bob!
Same here.. $85 for a stamped tag. He can do a reversed stamp. Just need to verify that it was reversed.
I asked him about the glove box tag and he doesn't have one for '51/'52 years. He has them for '48-50 and '53-up.
Ilya
Old 05-23-2006, 06:52 PM
create's Avatar
create create is offline
create is starting off with a positive reputation.
i know mid-fifties does this for the 53-56, all you have to do is provide proof of ownership.. maybe you should call them and ask who does their's because im sure they dont actually do it at their shop..
Old 05-23-2006, 06:57 PM
Blue50F-1's Avatar
Quote:
Have you got a pic of one of your other plates from the same year? The plates on my 50 are deffinately original, and deffinately engraved...NOT stamped. Your rig's a different year than mine, so I can't say for sure if they stamped them or engraved them, but I think I could tell the difference if I could see a pic...then again, maybe you can tell the difference.
Old 05-24-2006, 12:19 PM
51PanelMan's Avatar
Quote:
I have VIN plates from two different '49 trucks. I should check my '51 Panel. It has both VIN plates. My '51 Panel is a late '51 model and does have the same VIN tags as my '52.
Ilya
IS IT STOLEN? VIN help please filthy6 1957 - 1960 F100 & Larger F-Series Trucks 3 05-21-2015 11:36 AM
Cowl Vin Tag stamping numbers on new plate Question on Stars jmadsen 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 11-21-2013 07:30 AM
1960 Canadian VIN cal401 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 07-14-2012 06:14 PM
VIN Plate Vexations Philo Beddoe 1961 - 1966 F-100 & Larger F-Series Trucks 28 05-14-2010 09:06 PM
Decoding VIN beentook2 1967 - 1972 F-100 & Larger F-Series Trucks 7 06-20-2008 12:06 PM
Tags
1935, chrysler, classic, ford, identification, plate, plates, punch, reversed, stamp, tag, truck, vehicle, vin, vintage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
