New starter installed....still grinds occasionally....
Question for ya, I just put a new starter in my 97 350 because it had been grinding some lately. Today i went to start it and it grinded again. I'm hopping i don't have to replace the flywheel, and was wondering if there was some adjustment that i missed, or something else. Also, do you think the problem would get worse if i just left it alone for now? it only grinds every once in a while, and i dought that i have the tools and equipment to install a new flywheel. any info would be great... thanks!
-Robb
-Robb
ha thanks Ryan for the confidence booster..... I'll pull the starter off tomorrow and see what i'm up against. How much does a new flywheel run? I'm assuming I have to drop the tranny to get into the flywheel area. Any special tools that I might need? I have standard back-yard mechanic stuff.... torque wrenches, air tools.... etc... (Saw-Zall my favorate tool!)
-Robb
-Robb
I had the same problem after a rebuilt starter was installed. It turned out to be the starter. The shaft that the gear slides on was cruddy....wouldn't allow the gear to slide far enough to engage the flywheel, grinding occationally.
The tolerance on the gear/shaft is really close and most remanufacturers don't replace either of them, they just buff the shaft.
Hope this helps.
JIM
Hope this helps.
JIM
When you remove the starter, the part that goes inside the bell housing holds the end of the shaft. The gear assembly that you can see on that shaft is the bendix. If you turn the gear one way it will push out (away from the starter motor) on the shaft. It should travel smoothly (it is spring loaded) and go almost to the end of the shaft, if you try and turn it the other way it will not move. Look for burrs or rough spots on the shaft, if you find any use (fine 300 grit or up) sand paper to smooth out and then light oil.
