Main Bearing Torque Sequence? - Ford Truck Enthusiasts Forums
Old 05-22-2006, 04:46 PM
53fatfndr's Avatar
53fatfndr 53fatfndr is offline
53fatfndr is gaining momentum as a positive member of FTE.53fatfndr is gaining momentum as a positive member of FTE.
I'm replacing the oil pump in my '71 400 and I am also replacing the rear main seal as it looks like it has been slightly leaking. My book says to loosen the caps by 1/32" in order to pull the top portion of the rear seal. My question is, is there a torque sequence for retorquing the caps back in, or just go ahead and torque them to specs, (95-105 ft-lbs)? I assume there isn't, as there is no info in three of my books . Thanks
Old 05-22-2006, 05:52 PM
kotzy kotzy is offline
kotzy is starting off with a positive reputation.
On a worn in engine it will not matter, however become a creature of habit
and like nailing down a sheet of plywood start at the center first. Just keep it
even from side to side as well.
Old 05-22-2006, 06:48 PM
53fatfndr's Avatar
Good deal, thanks
Here's another question: The book says to remove the pin in the rear main cap and fill it with silicone because I am using a 2-piece seal. Has anybody done this with luck...in that it hasn't leaked?
Old 05-22-2006, 07:55 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
AFAIK the pin is to keep the old rope seal from turning. I pulled the pin and used a regular two piece seal on my 390 with no problems. Unfortunately I do not remember if I filled it with any sealer or if it was drilled all the way thru. I may have just ground it down and put it back in to fill the hole or even left it out. The OEM manuals do not mention filling the pin hole with anything. Apply sealer to the rear main cap as specified in the locations shown in the manuals.
The tightening sequence is kind of the reverse of what was mentioned above...
351M/400 Main bearing cap bolts are torqued to 35-45 lb-ft.
-Install the rear main cap with the rear surface flush or slightly ahead of the rear of the block.
-Install the other caps except the thrust cap #3 and tighten to specifications.
-Install the thrust bearing cap with bolts finger tight.
-Pry the crank forward against the upper half surface of the thrust bearing.
-Hold the crank forward and pry the thrust bearing cap to the rear.
-Retain the forward pressure on the crank and tighten the thrust cap bolts to spec.
-Force the crank to the rear and check crankshaft end play which should be 0.004-0.008".
Old 05-22-2006, 08:03 PM
53fatfndr's Avatar
Thanks for the response, Eric I do appreciate it
Old 05-22-2006, 08:05 PM
Torque1st's Avatar
Posting Legend
Have fun tonight!
Got to run, late for a meeting...
Old 05-22-2006, 11:33 PM
Torque1st's Avatar
Posting Legend
Well did you get the mains torqued?
Old 05-23-2006, 12:11 AM
53fatfndr's Avatar
Quote:
I got the rear main cap ready and a few other things. I put silicon in the pin hole and punched the pin back in until it was flush on the inside. It's a real tight fit, so I shouldn't have any problems. When I pulled out the old seal I found the source of my leak. My previous gasket tore, (about an inch) across the pin as the new one was installed. So, I was doomed from the beginning and I didn't even know it. I was using an old Chilton's manual from the mid 70's when I assembled this engine years ago and it made no mention of removing the pin, as I believe people were still using the rope style back then. Either way, my new books DO mention removing the pin for the split seal, which is what I have. This is interesting, I'm glad I found the source though. So, first thing in the morning the cap gets put back on. I got the standard oil pump and everything ready to go. I move slow...."measure twice, cut once", you get the idea
One question though, are you sure about the torque specs you gave me? I think those are for the rods, not the crank bearing caps?
Old 05-23-2006, 02:54 AM
Torque1st's Avatar
Posting Legend
That seemed low to me but it is right out of the 1977 OEM Ford truck manual I have. I rechecked and that is what it says. I will check some other sources.
A Chilton's lists 35-45 for a 1977 but 95-105 on a 78-80.
It also lists 35-45 for a 77-86 351W.
A 73-9 Haynes manual lists TWO main bearing cap bolt specs:
3/8"-16 as 35-45 lb-ft
1/2"-13 as 95-105 lb-ft
It does not differentiate between years.
My old 1974 Motors manual that covers cars but not trucks lists the following for the 400:
1971-2 as;
95-105 lb-ft
1973-4 as;
My loose-leaf 78 OEM truck manual lists 95-105 for the 400.
A website that does not differentiate for years calls out 95-105 for the 351C/M but does not have a listing for the 400.
Did the machinist machine (line-bore or line-hone) the crank bore? If he did you will need to use the torque values he used for the machining process. Check with them and see what they used. I would use 95-105 for the 1/2" bolts that should be there if they did not machine the crank bore. Personally I have never seen 3/8" main cap bolts on these engines but I have only torn down 4 of them.
Just for reference the 390 and 460 is listed in the 77 manual at 95-105 lb-ft
Torque values listed are for clean and lightly lubricated threads.
Torque is a terribly inaccurate method of setting fastener preload...
Note:
Machining the crank bore changes the crank to cam centerline distance and throws off the transmission alignment. It can also change the deck height. Normally they try to barely touch the top of the crank bore but that produces an out-of-round crank bore. Changing the cam centerline distance requires a custom timing chain set. So many chances for a FUBAR...
BTW- "measure twice, cut once" is the best policy.
Old 05-23-2006, 06:41 PM
53fatfndr's Avatar
I checked three books I have:
A 1974 Chiltons which covers American Cars from '67-'74. In the Ford section, it has it at 95-105 lb-ft for the mains. Two other books I have are, Tom Monroe's book, or should I say the 335/385 Ford owners Bible and another Chilton's covering '76-'86 Ford trucks. Anyway, all three specify torquing the mains at 95-105 lb-ft. I went ahead and torqued the mains at 100 lb-ft. I'm not sure what to say about the numbers you have in the Ford book for the '77. I'm thinking it's either a mistake or that year used 3/8" bolts for the mains. Mine are the 1/2"-13, and the crank bore was not machined, so I went with 100 lb-ft and got them torqued in there today. Again, thanks for the info, I appreciate it.
Old 05-23-2006, 07:31 PM
Torque1st's Avatar
Posting Legend
No problem! I just pulled out all my books and found the strange numbers in more than one. The 77 OEM manual did not mention anything about bolt sizes but others did. 4 different brands of manuals had the strange numbers for different years, check out the post above. The 74 Motor's manual came out in 74-75 way before an error in the 77 OEM manual... Someone here may have an explanation tho.
Good luck with the engine!
Old 05-23-2006, 07:49 PM
grclark351 grclark351 is offline
grclark351 is gaining momentum as a positive member of FTE.
the 3/8"-16 @ 35-45 ft/lbs bolts are the outer bolts of a "4 bolt main" engine. the 1/2"-13 bolts @ 95-105 ft/lbs are the "2 bolt main" bolts that everybody has.
i bring them up to spec in stages like the head bolts, and double check them after a refreshment.
Old 05-23-2006, 08:42 PM
Torque1st's Avatar
Posting Legend
The strange thing is that 4-bolt mains were never offered in the 400 and the 77 manual only listed the 35-45 figure...
Old 05-23-2006, 09:35 PM
that could really cause someone some problems!
the 400 engine that the factory 4bbl intake came from was a 4 bolt, according to the guy that had the intake. and there are a few other "old codger reports" of the 400 4 bolt block, that'd really be cool for one of those to surface.
351m/400 torquing sequence breezesboy 1973 - 1979 F-100 & Larger F-Series Trucks 1 05-04-2015 06:37 PM
Cylinder head torque sequence V8 California Codfish 1961 - 1966 F-100 & Larger F-Series Trucks 10 03-30-2012 02:01 PM
Torquing Sequence wulleebullee Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 1 05-17-2011 09:51 AM
torque spec on the rear main seal cap 292 halltm 1961 - 1966 F-100 & Larger F-Series Trucks 2 04-13-2011 11:25 PM
302 torque sequence for mains my93 Performance & General Engine Building 2 03-31-2009 02:47 AM
Tags
351w, 460, bearing, main, sequence, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
