Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-21-2006, 05:47 PM
toolebox1 toolebox1 is offline
Garage is empty, add now
toolebox1 is starting off with a positive reputation.
Angry Turbo Ranger 2.3?
What can my son do to put a turbo on his 2.3 4 banger so it won't blow up?
He has killed 3 engines trying to make it work.
Are there special things he needs to do to the engine before he puts it on?
Thanks!
  #2 (permalink)
Old 05-21-2006, 07:28 PM
wendell borror wendell borror is offline
wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.
Get the engine from an 86-88 ford t-bird turbo coupe, or get forged rods, and pistons, arp head bolts. Stock internals won't take much boost. Racer Walsh sells 2.3, and 2.5 turbo blocks with the internals upgraded for turbo application, www. racerwalsh.com
  #3 (permalink)
Old 05-22-2006, 10:17 AM
jamnjm jamnjm is offline
jamnjm is starting off with a positive reputation.
Question
First things first:
Year of Ranger and for the street (legal to pass smog needed) or racing?
What is he blowing up or breaking?
Non turbo junk yard engines or turbo engines?
Then we can direct you better. If it is an oiling system failure...there are several tricks to be done.....along with dist. drive failures.
Need more input.....
  #4 (permalink)
Old 05-22-2006, 03:23 PM
JD717 JD717 is offline
JD717 is starting off with a positive reputation.
how much boost is he trying to run too? a motor can only take so much before saying NO MORE NO MORE! then boom.
__________________
I have heard the turbo whine, and it is glorious.
  #5 (permalink)
Old 06-14-2006, 08:29 PM
nhswrld nhswrld is offline
nhswrld is starting off with a positive reputation.
i recently found an 88 turbo coupe motor that i just put in my 86 ranger...slight modifications to the heater box were needed, and im still trying to figure out how to rig in the wire harness...does anyone know the firing partern for the 88 turbo coupe?
  #6 (permalink)
Old 06-15-2006, 09:00 AM
jimdandy jimdandy is offline
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
Smile
Quote:
Get a Chilton's 8159 and a 8268. The wiring diagrams are correct in these manuals. Wire the Ranger according to the t-bird. You will have to switch a few pins on the computer and run extra wiring for the VAF meter. I assume you are using the Ranger harness which I think is easier. jim d
  #7 (permalink)
Old 06-15-2006, 10:33 AM
Smile
This also will help. I used this page to write the Ranger pins and wire colors out to the side in case I got lost. You won't be able to work straight thru, or if like me, get a lot of interruptions, and will probably forget where you are.
http://rothfam.com/svo/reference/PEtoLA.pdf
jim d
  #8 (permalink)
Old 06-16-2006, 12:48 PM
Old Rob Old Rob is offline
Old Rob is starting off with a positive reputation.
www.powerbyace.com in thier technical section has the firing order for the 2.3 S.O.H.C lima engine.
There is only two differences between the turbo and non turbo short blocks. One is the turbo has dished (lower static compression ratio) forged pistons, with the exception of the first year. The turbo block had a boss cast into it for turbo oil drainback, all later blocks turbo and non turbo have this. The crankshafts and rods are all the same!
  #9 (permalink)
Old 07-10-2006, 09:42 AM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
1-3-4-2
No different than most 4 cylinder engines out there.
__________________
2012 F-150 Lariat, SCrew, EcoBoost, 157"WB, 3.73 axle
Tags
23, 86, box, coupe, engine, firing, harness, heater, order, put, ranger, turbo, turboranger, wire, wiring, wwwracerwalshcom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
