Blend Ratios
Originally Posted by BigRed350
I've been reading about the "B" numbers, but really don't understand what they mean. What is "B100" and "B20"? What is better for an older vehicle, or with high milage?
Thanks in advance.
Thanks in advance.
I use B-100 in every diesel on my farm except in winter when I use B-80 because of the higher cloud and gell point. I have a 91 Dodge Cummins with over 500,000 miles on it and it loves the stuff! I also use it in a 1948 HD-6 Dozer with over 16,000hrs on it and it too runs great. It takes out the "diesel-rattle" and runs much smoother too.
FABMANDELUX.
There are a couple of reasons that blends are more readily available than B-100.
First.
No engine maker recommends greater than B-5. That has to do with some still unanswered questions about the long term consequences of using BD, there just hasn't been enough research done to be certain it is safe for the engine. B-5 blend meets the current ASTM standard for regular (Petro based) diesel so engine makers consider it safe. Some engine makers will tacitly approve B-20 but warn that warantees will be void if any problems can be traced to the use of it. Standards are currently being developed aand research is in progress to answer these questions.
Second
BD has a higher "cloud point" than regular diesel, that means it will crystalize and start plugging up filters at a higher temperature, which can cause problems in colder parts of the country. This problem can be resolved by blending in some reg #2.
Third
The BD production capacity, in the US, is still in its infantile stage. It would be impossible for it to keep up with demand if everyone started using B-100.
Note
As clean air regs demand cleaner burning fuel you may see an acceleration in the use of BD. It decreases CO2 emissions, reduces particulate emissions, and it is extremely low sulphur yet lubricates better than high sulphur content fuel.
First.
Second
Third
Note
Originally Posted by Phydeaux88
I am in the process of assembling my reactor when I get done I will probably run a blend just so I dont have to spend all my spare time making BD.
Ok, over the past few days since I originally posted this question I have noticed guys talking about all kinds of different numbers. Like someone was talking about B99, B24, B25, etc. Why all the different ratios? I mean, why would someone or company go to the trouble of making B99 when they could just go all the way? I understand the "need" for a B5 if that's what the manufacturer will approve of, but why all the different (and sometimes so little difference) numbers??
Perplexed!
Perplexed!
Perplexed!
Perplexed!
FABMANDELUX.
Ahhh!!!! Of coirse, POLITICS!! I should have known. So then, as you say, "no fuel company in their right mind" would sell B100 for the same price as B99, since they wouldn't get their "rebate" from the feds. Is the B100 people speak of really B99, or is it sold at a much higher price to offset the "loss" of not getting the federal money?
alchymist
10-22-2005 12:44 PM
