Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-20-2006, 10:48 PM
willbd willbd is offline
Garage is empty, add now
willbd is starting off with a positive reputation.
Talking Here I go
Just completed the upgrade to WVO.
Going for the first test ride.
Bryan
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Bryan Will
  #2 (permalink)
Old 05-21-2006, 08:32 AM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
good luck. Tells us more about the truck and the conversion
  #3 (permalink)
Old 05-21-2006, 09:26 PM
Talking
The truck is a 95 350 with 145K.
I purchased a Greasel kit and installed it last Saturday.
I added an electric tank switching valve on the return line so when the engine is running WVO flows back to the tank instead of looping the return back to the fuel pump. If the fuel filter on my WVO plugged them I would pull fuel thru the return line to the pump bypassing the heated WVO filter.
The plan is to run a mix of diesel and WVO in my heated front tank and bio-diesel in the rear.
Bryan Will
__________________
Bryan Will
  #4 (permalink)
Old 05-22-2006, 08:25 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Quote:
Not a good idea. Diesel and VO will not stay mixed. They will seperate into layers and you will be running straight diesel or straight VO so why bother.
Additionally if you should happen to shut down on straight VO your gonna have a problem getting it started again.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #5 (permalink)
Old 05-22-2006, 08:26 AM
Dave Barbieri Dave Barbieri is offline
Dave Barbieri is starting off with a positive reputation.
Bryan Will
Bryan -
There's been a LOT of discussion on the compatibility of vegetable oil and diesel fuel. Go back and check these threads:
http://www.ford-trucks.com/forums/sh...=488066&page=3
http://www.ford-trucks.com/forums/sh...d.php?t=490845(Post #13 is my response on a simple test to see this for yourself.)
Bottom line - don't mix the two! Heat/motion don't help, and in the end, it's your injection system (and your wallet) that suffer.
__________________
1985 F250 XL 6.9
T-19 4 spd, A/C, PW, CC
  #6 (permalink)
Old 05-22-2006, 09:13 AM
Question
I am running a 2 tank system.
Front tank is heated with 90% WVO and 10% diesel.
I start on the diesel form the rear tank. When the fuel in the WVO & diesel tank is warmed up I switch to the front tank. The system has both heated filters and fuel line.
I under stand that WVO and diesel will separate out when the fuel in the tank is just sitting.
When you heat the fuel it should cause a thermal currant to help it mix the WVO and diesel. I drive about 20 miles before switching to WVO & diesel mix.
Do you see a problem with this system?
Bryan Will
__________________
Bryan Will
  #7 (permalink)
Old 05-22-2006, 09:21 AM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Bryan Will
Bryan, If you have a heated WVO tank there is no need to mix dino-diesel with your WVO. Just use WVO in that tank, adding D-2 is just a waste of $$$$$$$$$$.
FABMANDELUX.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #8 (permalink)
Old 05-22-2006, 09:28 AM
Smile
So what everyone is saying is just heat the hell out of the WVO and be happy running for free.
Bryan Will
__________________
Bryan Will
  #9 (permalink)
Old 05-22-2006, 09:30 AM
1935 Ford pickup
Bryan Will
Yep
FABMANDELUX.
__________________
  #10 (permalink)
Old 05-22-2006, 09:47 AM
Phydeaux88's Avatar
yup, mixing in the #2 accomplishes nothing and costs money.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
