Lift kits - Page 2 - Ford Truck Enthusiasts Forums
Lift kits
Old 02-05-2009, 12:33 PM
boo-yaa138's Avatar
boo-yaa138 boo-yaa138 is offline
boo-yaa138 has a great reputation on FTE.boo-yaa138 has a great reputation on FTE.boo-yaa138 has a great reputation on FTE.boo-yaa138 has a great reputation on FTE.
bump back up to see if you got the lift on?
Old 02-08-2009, 02:40 PM
boo-yaa138's Avatar
Old 02-15-2009, 02:46 PM
70crewcab's Avatar
70crewcab 70crewcab is offline
70crewcab is starting off with a positive reputation.
there is a pic in the gallery of an early 70's crew cab and in the info for the pic it says that the truck has an i beam flip. Has anyone done this instead of the aftermarket option?
Old 02-23-2009, 09:17 PM
Green_Monster Green_Monster is offline
Green_Monster is starting off with a positive reputation.
bumping for some info.......seems to be some conflict on the hwo much lift before messing with I beams.
I want maybe 1/12 to 2 " I figure I will be able to keep it in specs . I will be installing new springs at the same time. Any thoughts???
how did your lift come out?
Old 02-23-2009, 10:01 PM
Ford 67 Ford's Avatar
Ford 67 Ford Ford 67 Ford is offline
Ford 67 Ford is starting off with a positive reputation.
I got about a 4" lift on mine with stock beams, Bronco springs and mod. arms.
Old 02-23-2009, 10:25 PM
How did you mod the arms? I was looking in one members gallery where he extended the radius arm and modified the bracket
Old 02-23-2009, 11:00 PM
I happened to luck out a few years ago when I was going to lift it, I was at a wrecking yard looking for extra arms so I could extent and offset for the amount of lift that I wanted and I actually found some on a truck already modified. I believe you could use them unmodified but you'll need the extended brackets to mount them lower on the frame.
Old 02-24-2009, 07:07 AM
Ok I figure 1 or the other had to be the case. Thanks
Old 03-02-2009, 11:43 PM
dman71250 dman71250 is offline
dman71250 is starting off with a positive reputation.
Flip Flop
does any know if you can flip the I beams over to gain lift?
Old 06-04-2014, 11:39 AM
raasch09 raasch09 is offline
raasch09 is starting off with a positive reputation.
radius arms
Quote:
Andysautosport.com has extended radius arms you can buy
Old 06-04-2014, 03:44 PM
351Cleveland C4's Avatar
351Cleveland C4 351Cleveland C4 is offline
351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.
Holy old thread, batman.
Project: Smogie...RacinNdrummins IDI build RacinNdrummin Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2185 10-22-2016 10:22 PM
Front Springs '72 F250 1972RubberDuck 1967 - 1972 F-100 & Larger F-Series Trucks 1 05-11-2016 02:25 AM
1972 Coil Spring Lift? 72AmericanPR1DE 1967 - 1972 F-100 & Larger F-Series Trucks 12 02-19-2012 09:49 PM
2wd Front end lift grams72 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 08-12-2010 09:28 PM
67-72 leaf springs lift kits Craig Brakes, Steering, Suspension, Tires, & Wheels 1 01-24-2000 11:58 PM
Tags
1972, 2wd, 72, beam, camber, f250, fix, front, kit, lift, negative, pics, spacers, spring, suspension
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
