Adding cruise control to a 2005 F150 4.2L - Ford Truck Enthusiasts Forums
Old 05-19-2006, 09:58 AM
jamieay jamieay is offline
jamieay is starting off with a positive reputation.
Hello! I'm trying to figure out how / if cruise control can be added to a 2005 F150 with the 4.2L V6. I bought an aftermarket kit, popped the hood, and then learned all about electronic throttles . What (aside from adding the cruise control switches) do you have to do?
Thanks!
Jamie
Old 05-19-2006, 05:04 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Old 05-22-2006, 10:29 PM
xtrm1stang xtrm1stang is offline
xtrm1stang is starting off with a positive reputation.
it's easy, but the kit from the dealer, and have it installed there, it is a new steering wheel wiht cruise switches in it, and then teh dealer must reprogram the pcm and turn on the cruise control function, that's it, dont know the price of the kit, but should be 1 hour to install
Old 05-22-2006, 10:32 PM
Cruise Control
Thanks for the info! Do you have (or can you get) a part number for the kit?
Thanks!
Jamie
Old 05-23-2006, 08:45 AM
orgnova orgnova is offline
orgnova is starting off with a positive reputation.
sometimes you can find a steering wheel with cruise on ebay alot cheaper than the dealer. the dealer will charge about $50 to turn it on. its pretty easy to do yourself.
Old 05-23-2006, 09:00 AM
Cruise Control
Unfortunately my local dealer seemed somewhere between clueless and uninterested. Maybe I'll see if I can get a wheel off of eBay like it was suggested and talk to another dealer about reflashing the PCM. Has anyone here had this done (or done it if you're a tech)?
Thanks again!
Jamie
Old 05-23-2006, 11:06 PM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
FTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to all
Jamie,
I had purchased my steering wheel for about 100bux, (98.xx) from a dealership in the next state over (NC) and went back home to Greenville and had my dealership put it on. This was also a clueless thing for them too. But after careful coaxing and the potential that I'd bring'em return buisness for similar things, I talked them into it. They figured if their techs knew how to replace one for (any) reason they should know how to put on in for the first time. I did remind them however that it would have to be turned on in the pcm/ecm (they prolly knew already). So right less than 70bux and a hr later, out comes my truck with cruise control. Final cost ...approx. 169$ including a brand new steering wheel. I would have attempted it myself, but I was home on vacation- and wanted to keep my wrench turning to a minimum.
Old 05-23-2006, 11:16 PM
I forgot to mention,
I think I have the p/n scribbled down somewhere...if not, I believe there was a few lenghty threads on the (by searching) "Adding cruise" topic...maybe you can catch the p/n there too...
Old 05-23-2006, 11:28 PM
may be tricky trying yourself, remember your messing with the air bags, and I have seen them deploy while the veh was in a shop and the tech didn't follow the instructions correctly
Old 05-29-2006, 01:41 PM
aerio aerio is offline
aerio is starting off with a positive reputation.
PLS post P/N #
Old 05-29-2006, 08:04 PM
Lightbulb
Quote:
Originally Posted by aerio
PLS post P/N #
http://www.fordaccessoriesstore.com/fas/b2c/catalog.asp
Black Speed Control
Part Number: 4L3Z-9A818-AAA
MSRP: $165.93
Note!: I didn't pay nearly that much by purchasing it locally from a dealer. (Dale Jarrett Ford) The dealer had 4-5 on the shelf- everyone else would have had to order it. The 165. is pretty close to what I paid for the kit and install together. I purchased it at Dale Jarrett and had my Local dealer (Fairway Ford) do the swap.
Old 05-30-2006, 10:45 AM
Thank You for the P/N # do you have a # for Dale jerrit thanks
Old 05-30-2006, 07:25 PM
Lightbulb Web addy and contact info....
... do you have a # for Dale jerrit thanks
http://www.dalejarrettford.com/Department-Parts.aspx <-web address
Phone: 704-283-0616
Fax: 704-225-1671
Email: ()
Old 12-15-2012, 03:57 PM
hhott71 hhott71 is offline
hhott71 is gaining momentum as a positive member of FTE.
I see y'all are clueless as the ford dealer about installing cruise control on the 2004 to 2008 F150.
www.bought4less.com sells the cruise control kit for $120. It must have the ECM flashed.
Great thing is it looks and operates like factory.
Old 12-15-2012, 04:01 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Clueless?
I dunno, maybe this module wasn't available way back in '06 when this thread was first posted. And '07's and '08's weren't even being made yet.
Stewart
cruise control ItsAFord55 1997 - 2003 F150 1 03-02-2014 01:11 PM
Aftermarket cruise control? ItsAFord55 1997 - 2003 F150 0 03-02-2014 01:09 PM
add cruise control later? paulkcbulm 1999 to 2016 Super Duty 7 01-05-2010 02:28 PM
adding cruise control benblaque 1997 - 2003 F150 4 08-15-2009 02:13 PM
Aftermarket cruise control? BigBlueMacDaddy Aftermarket Products 8 11-01-2007 08:55 PM
Tags
2005, 2006, 4l3z9a818aaa, add, control, cost, cruise, f150, ford, install, kit, pn, price, speed, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
