Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-18-2006, 07:16 AM
Butch(OH) is starting off with a positive reputation.
Help, my 350 SD is possessed, long post
Hello again board, been a while since I begged upon your knowledge but my 2001 F-350 has been taken over by demons. Sorry for lore but could not shorten and get all the facts. Everything was fine when I parked it yesterday then when I go out to start it this morning the blower fan was running. Ignition switch off, key in my pocket. Turned the control to off and the fan quit. I have had to replace the relay before but never had it turn on in the night? Truck starts OK and when I start to move the OD light starts to flash. Truck goes and shifts OK but speedometer is crazy, been there before, the sencer on top of the rear end right? Well I keep driving because everything acts normally otherwise and a few miles down the road the door chime starts up at about 1/2 normal db. No seat belt light or door ajar lght on the dash, just the chime, 5 times then pause, then 5 times etc. I start to think I should turn around and take another vehicle to work at this point but the thingis going along all right. Chime did quit for a while then started up again just as I got to the office ( 1 hour drive) Get to work and shut off, blower still running so I pulled the relay (have a spare in the box) new relay clicks in and runs blower too. Then I noticed head lights were still on but no chime. Shut everything down and came into the office and got on here.
Probably a long shot but what the heck?? Has been raining here for about two weeks straight and truck sits out. Anyone one want to take a shot at this? Oh yeah its a 4x4 'stroker
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-18-2006, 07:32 AM
Ed in Maine is starting off with a positive reputation.
Wow, I think I would have jumped out expecting a bomb to go off any second! The only part of it all that is disturbing to me is the OD light flashing, this should trigger a service code in the computer. May be worth the $50 to have the dealer hook it up to the computer? Could be something in the brain/ECU that is causing the other electrical issues. It is obviously trying to tell you something, maybe morse code
Ed
__________________
99.5 F250 CC 4x4 7.3L 3.73's 285/75/16, MM449SS Hubs, 6637 mod, DiabloSport chip, 4" Exhaust, ISSPRO Pyro and Boost gauges, Bio in summer, Rotella Synthetic oil, 146K mi
  #3 (permalink)
Old 05-18-2006, 07:40 AM
GONE4X4 is starting off with a positive reputation.
windshield replaced recently?? almost sounds like water ingestion in fuse box//gem modules--look really close at box for green fur!!--odd though that a water leak would just start to occur!
  #4 (permalink)
Old 05-18-2006, 07:41 AM
Beast12's Avatar
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Quote:
Possibly a leaking windshield. The water runs down onto the fuseblock area, I believe. May be something to look into.
-Matt
EDIT: Look at this: http://www.ford-trucks.com/forums/sh...highlight=leak
__________________
-Matt (FTE Super Moderator)
2001 F-150 S/C XLT 4x4 Sport
Check Out The Ontario Chapter
"He who is tired of WEIRD AL is tired of life" -Homer Simpson
  #5 (permalink)
Old 05-18-2006, 09:25 AM
Thanks guys, truck has been sitting 2 hours and I just got out to check things out. Door chime has returned to normal as has the head light warning chime. Heater fan still runs when it souldnt. Fuse box on the side I can see is dry, blew the dust out. Do I need to remove the fuse panel and look on the back side? Relay panels under the hood are dry inside but dusty blew them out and no changees. Is there problems where the wires go throughthe firewall on these? Going to drive across town now and check out the speedometer problem. thanks again
  #6 (permalink)
Old 05-18-2006, 09:59 AM
RudyF6 is starting off with a positive reputation.
Pull the fusebox/gem out and look closely at the seam around the fusebox. We were just looking at one yesterday that was dry, but you could see "green grunge" corrosion seeping out from inside. May have been wet in the past, and took some time to exhibit problems.
__________________
You can never be lost if you don't care where you're going!
  #7 (permalink)
Old 05-18-2006, 11:50 AM
FrEaKoFnAtUrE is starting off with a positive reputation.
is the wife trying to rub you out?
im stumped but i bet the puter is/was wet
i agree with the others either the fuse panel or the ECU
just a question have you had to boost it lately ?? i left my dome light on a few weeks ago and boosted my 01 the speedo didnt work and it was doing some funky things till i reset it.
__________________
2001 F250 Super Duty Banks Exhaust with OTTOmind waiting for Harley Wheels
  #8 (permalink)
Old 05-18-2006, 03:51 PM
ryaneverk2's Avatar
ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.
The solution to one problem (the five tones, then pause, then five tones, etc. etc.) is that it's an issue with the air bag system. Here's a thread with the info on that:
http://www.ford-trucks.com/forums/sh....php?p=3545574
__________________
Ryan Arthur
2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator/tee, ATS housing, BBHA, CCV Mod, SS HPX, DP-Tuner, BTS-VB, lots of LEDs, and more...
My Truck Pics
7.3L Common Mods/Maint. and Hard Starting
Super Duty Tech Folder and FAQ
  #9 (permalink)
Old 05-18-2006, 04:29 PM
FoMoCo05's Avatar
FoMoCo05 is starting off with a positive reputation.
Hey Butch have you checked all of your ground cables/wires ?? I have seen weird stuff happen when electrical system is losing its ground.
  #10 (permalink)
Old 05-18-2006, 07:38 PM
OK, more info. I am leanng towards the moisture deal. I left it running at the office with the heater on full blast for an hour, got kids warm in there, LOL. Shut it off and the heater motor quit like it should and everything has returned to normal. Tonight I tried to take the fuse box and whatever is on top of it, 'puter?, and cant figure out how to get it out below the bottom of the dash. wires are about 2" too short. There is LOTS of dust under there but no moisture like leak just dampness from air (I think) Need some help with how to get the thing out from under the dash. Some way to undue the wire harness beforehand? Once out can I take it aprt where it piggybacks together to clean and check connections? Sorry for all the questions and thanks again.
  #11 (permalink)
Old 05-19-2006, 05:32 AM
Beast12's Avatar
Don't be sorry for all the questions. If no one asked questions then what kind of forum would this be? It would be pretty boring. Someone will be by soon to help you out.
-Matt
__________________
  #12 (permalink)
Old 06-29-2008, 08:41 PM
tdb729 is starting off with a positive reputation.
I know this thread was started 2 years ago, but if anyone has their results to what the problem is, could you post it here? I have the same problems as others. Fan blower stays on after taking keys out of the ignition, overdrive light flashes on and off, strange clicking sounds behind the steering column. I had the GEM replaced a few years ago. My truck is a 2000 F250 PDS with 178,000 miles on it. I bought it new, so I know the history of it. I did replace both batteries and alternator a few weeks ago.
  #13 (permalink)
Old 06-29-2008, 10:16 PM
BareBones is starting off with a positive reputation.
Seems to me the first step just to get it out of the way, is a cold boot of the computer?
__________________
2005 F350 V10 6spd dually, 15K receiver. No 4WD, no LS, no A/C, no special cab - just a lean mean towing machine!
  #14 (permalink)
Old 06-30-2008, 07:18 AM
GregN is starting off with a positive reputation.
Quote:
To take the whole assembly out, you need to remove the electrical connections. Just unplug the ones that go to the GEM, and you need to unscrew the two large square ones that go to the back of the fuse panel. I believe it is an 8 or 10mm (But don't hold me to that). You will need to use a 1/4" Drive because of space limitations. It will take a little patience. Make sure that you undo them all the way, because backing the screw/bolt out actually pulls the connection apart.
__________________
-Greg (21)
(Early) 1999 F-250 Super Duty 7.3L PSD: Volant Intake, Silverline 4" SS Turbo Back Exhaust, Banks 6-Gun (DP Tuner soon after a few more upgrades), Dynatrac Hub Conversion, Warn Premium Locking Hubs, more to come.....
  #15 (permalink)
Old 07-01-2008, 05:43 PM
KR DRIVER is starting off with a positive reputation.
I Have Heard There Is Computer Under Dash On Drivers Side ,and That Over Time Windshiels Seal Will Let Water Down Through.
2003 F 350 King Ranch 4x4
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
