Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
  #1 (permalink)
Old 05-16-2006, 11:13 PM
buffchick buffchick is offline
Garage is empty, add now
buffchick is starting off with a positive reputation.
towing with a lightning
I have a 1999 Lightning with 40,000 miles and mods of air-kit and headers back through exhaust, and factory tow package. Will towing with it effect the performance mods and put too much strain on the truck? Does anyone ever tow with a Lightning? I have never seen it....A little help,,
Buffchick
  #2 (permalink)
Old 05-17-2006, 05:08 AM
sigma's Avatar
sigma sigma is offline
sigma is starting off with a positive reputation.
I have towed with mine many times. I have towed two wheeled utility trailers, car dollies with car, boats, loaded car trailers, and loads of lumber. Some loads were over the 5,000 pounds rated limit. The Lightning easily handled it all including one trip through the Rocky Mountains with a loaded car trailer.
__________________
The point of life's journey is not to arrive at the grave safely in a well-preserved body, but rather to skid in sideways, totally worn out, screaming "....HOLY ****!....WHAT A RIDE!
  #3 (permalink)
Old 05-17-2006, 01:58 PM
pronstar pronstar is offline
pronstar is starting off with a positive reputation.
IMHO the only strain would be tranny heat. So drive it like you'd drive anything else when towing - carefully and not racing around - and you'll be fine.
These trucks are rated to do the work of a real truck. Unlike some trucks that are for performance only, and not rated to tow or haul a meaningful load.
__________________
97 Expy XLT, 5.4L, 2WD | Intercooled Procharger| 10.5 psi | Full fuel system mods | 4.10 LSD | Tuned by Swanson Performance
  #4 (permalink)
Old 05-17-2006, 03:25 PM
Is there anything I could add to the truck to make the tow even easier?
  #5 (permalink)
Old 05-17-2006, 03:47 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
1994 Ford Lightning
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
The 4R100's in those trucks are pretty stout. You could put an aftermarket valve body in the trans to make the shifts firmer, but it's not really neccessary. Otherwise, make sure the trans fluid changes are done regularly, and your load is properly balanced.
On a side note, you wouldn't believe how many owners use Lightnings to tow their race trucks to Lightning Fest every year (GEN 1's and 2's). Most of these tow pigs are stock, or near stock.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
  #6 (permalink)
Old 05-17-2006, 06:12 PM
I'd recommend an aftermarket tranny cooler...I don't think the factory unit is adequate, but this is just my opinion.
__________________
  #7 (permalink)
Old 05-18-2006, 12:44 PM
Well, you guys have been really, really helpful to me. I guess i will start shopping for that boat then!!!!,,Thanx again,
Buffchick
  #8 (permalink)
Old 05-26-2006, 04:31 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
2001 Ford Excursion
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Quote:
In some cases they are and in others, they aren't, it just depends on what you're towing, how much you're towing, and how often you tow. With an aftermarket cooler, it's much bigger and much more effiecient than the stock setup. In this case a small invesment will yield a big return. This is just one of those "better safe than sorry" sort of things.
__________________
Excursion & 6.7 Forum Mod Death Row Inmate #21
2001 X PSD Limited, 203*, HD4R100, GEARHEAD TUNES, MBRP, Hpx, Frx, T500, RAS, Cass Stage I's, 38R w/HFO, M208, 6.0 tc/ic, CFM+, 6 inch lift, 4.10 Gears, Coolant Filter, CAT ELC, AE, Afe 6637, Riffraff Boots. Too much to list, but FAR from stock FTE Guidelines
Quote:
Originally Posted by Toreador_Diesel
Ford didn't call it a "Powerstroke Diesel" becuase they thought it would be a cute name to give a diesel engine...
  #9 (permalink)
Old 06-16-2006, 10:33 AM
02 LariatFX4 02 LariatFX4 is offline
02 LariatFX4 is starting off with a positive reputation.
I put one in my 99 dodge 5 yrs ago and used it for 2 yrs towing 5000lbs plus a day ...(really..worked 7 days a week to be able to afford a new ford..lol) and I am the only person I know who has towed a heavy trailer for an extended period daily who never had the dodge tranny sh&t the bed....I believe in aftermarket coolers now more than ever...I put one on my current truck to and have had 0 troubles as well...not that I expected them like I did with the dodge....and to my knowledge..(I sold it to a guy in my buisness who tows a work trqailer to..) and he has still had no trouble with the tranny....I'm sure had I left it stock it would have been found on the 401 here in Toronto before I sold it 3 years ago....
__________________
http://www.freewebs.com/mcgratts16/new%20truck.jpgHAVE YOU DRIVEN A FORD LATELY?
  #10 (permalink)
Old 06-16-2006, 03:47 PM
How much does something like that run, installed and all?
  #11 (permalink)
Old 06-16-2006, 07:19 PM
you can get them varying from 250 to way way higher...not even sure how high...lol I paid 500 installed for the one I have and had...I went to the same guy to get them both done..funny enough..I don't even know the brand or part number...may be able to find the reciept..I'll check but I am horribly disorganized..as I am sure I have it..I may not find either receipt
__________________
  #12 (permalink)
Old 06-22-2006, 04:40 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
+1, good info.
Plus, I like the idea of adding an aftermarket tranny cooler. You don't have to break the bank to do that either. The Factory Tech cooler works well and doesn't cost an arm and a leg.
I have a buddy in NorCal who uses his stock Gen 2 Lightning to tow his race prepped Gen 2 L to the track without any problems.
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
  #13 (permalink)
Old 07-22-2006, 04:22 PM
nordy racer's Avatar
nordy racer nordy racer is offline
nordy racer is starting off with a positive reputation.
thats all i do with my Lightning.. i tow a 5000lb boat every weekend. i also tow my race car with my sportbikes in the bed.. i HAVE NOT HAD ANY PROBLEMS with my ride.
i'm running a 4lb lower and a K&N without a tune (i know i'm pushing it)
Click the image to open in full size.
  #14 (permalink)
Old 07-22-2006, 06:39 PM
Stewart_H's Avatar
1999 Ford F-250
My Garage
Nice GN! I think i've seen that picture a few times in a certain sig at another site.
Stewart
__________________
  #15 (permalink)
Old 07-23-2006, 06:42 PM
Quote:
Stewart
thanks man.. I'M STILL NOT HAVING ANY LUCK ON SELL HER (the lightning)...
Tags
2001, 2002, car, cover, f150, ford, forum, gen, harley, lightening, lightning, roll, tonneau, tow, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
