You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Well just thought I'd create this to see what everyone is up too or soon to be getting themselves into...
Right now I have installed all new wheel bearings, spindle bearings, brakes, rotor and axle joint on the driver's side and I do have all the parts but I just need to find the time to do the same to passenger side. When I do the other axle joint while I'm at it I might just go ahead and do both u-joints in the driveshaft since the rear one has a little slop and I can feel it when I shift gears and get back on the gas. Another project I have lined up is the exhaust. I currently have on order the walker 45166 "Y" pipe for my 300 then I'm also going to get a 2-1/2" magnaflow high flow cat, magnaflow muffler and use 2-1/2" piping, and after all that it should really wake up the truck
Other projects I need to start on is replacing the rusty oil pan along w/ new pump and sometime next spring I really want to pull the whole truck apart to the chassis and take care of all the rust issues but thats way on down the road...
My current project I completed last fall. I did a lot of mods to my 99. I installed (true) dual exaust, K&N intake,Tint, Line X Bed Liner,stainless step rails, stainless bed rail, billet grill, CD system with MP3 capacities, and a weekly bath (even under the hood) to keep it all looking sharp.
Other than that, the only thing pressing is to get my boat in the water. The starter crapped out yesterday, sending it out for a rebuild.Anything with the name Marine on it cost double.
I am looking for a 80's/90's Diesel IDI or Turbo to work on again, any leads?
__________________
1990 F-250 7.3 IDI /1993 E-350 5.8 /1994 E-350 5.8/ 1999 F 150 4.2 SC /1999 Explorer EB 4.0 SOHC /2002 F250 SC 5.4 8Ft Bed
Hey all! I'll be on vacation the week after Memorial Day and I plan on installing the new rad support I bought. Been sitting in the living room long enough for the wife to say it looks like an auto parts warehouse. 2 weeks ago I finnally got the trailer hitch on and a Grant custom wheel, nothing fancy but a lot easier to turn than that 18 inch monster that used to be there. Almost forgot the new harmonic balancer that'll be going on then too. Maybe, I'll have enough time to float the boat for a couple of hours......................... Hmmm............... we'll see
__________________
Henry
1970 Ranger XLT The wife says it looks and rides like a truck.
Actually I just got done putting a new front tire on my yamaha bigwheel. I took it to the shop where I bought it and they serviced it and I had ordered a tire for it from them but they didn't put it on there and if you know anything about a bigwheel they are a little different and being almost 20 yrs old parts are kinda hard to come by so they didn't want to put the tire they ordered because it was more of a fourwheeler tire and I need one with a more rounded profile. So I found the correct tire online but they wouldn't mount it because I didn't buy it there so I took it to the local tire place and they took off the old tire and installed a new valve stem all for $6, I don't see how you can mount a tire and a new stem for that but hey I'll take it
My front Dana44 is coming along pretty freakin' great! Thats where I have been spending alot my after work hours instead of on here 4.56 gears are in, all new bearings and seals, got the drivers side axle shaft in with new 5-760X U-joints. Went to install the passenger side axle shaft and found it was short, PO put in a Bronco/F-150 shaft so thats ANOTHER thing I have to order for it. . .still need to get new rotors put in and machined (or at least checked). . . Hopefully I can have it slung back under the truck by the end of this weekend, then it gets it's final coat of paint and the engine gets looked at
Other than that, massive cleaning and fixing on the house. . .
__________________
Steve
2004 F150 STX
1978 F-250 4X4
1987 F-250 4x4 VIRGINIA CHAPTER Virginia Chapter Website
Not really my project but dad is conning me into helping him do the clutch on his 87 f150 2wd w/ 300 and he wants to also do a tranny swap while we're in there. He has a 3 spd w/ od that the gearing sucks on it but you also do get od with it. His transmission is a 2 piece which has a seperate bellhousing and case with an external slave cylinder. I tried calling the local bone yards but they are not very helpfull with me since we're swapping transmissions and they are using the computer to enter the info in and supposedofly they need more info than what I can give them, although one of them does specialize in fords but they didn't answer so I'm gonna try them first thing in the morning. Also my neighbor is a ford mechanic and is very sharp but he's rarely home so I don't know when I'll get to talk to him about it.
3. Cut out the muffler and go straight pipe with what I have.
Want a deeper sound without any drone.
Reg
01 F350 7.3L, crew, dually.
__________________
2001 F-350 7.3L crew Lariat 4X4 dually 8' bed, 6637 filter, straight pipe, 220 amp alternator, illumination by PIAA and KC, thrust by Dp tuner, braking courtesy of ART cryogenics and Performance Friction, on board air, lane clearing by Nathan Airchime train horns (see em under Articles), car catcher by Road Armor.
Spread out the parts Thursday. Will begin installation this weekend or Monday.
BTM is sitting in box on rear seat. Still haven't decided straight-pipe or BTM. Leaning toward muffler because I want deeper sound not annoyingly loud to others.
Reg
__________________
I've decided to take off all the moulding except for the trim around the cab and wheel wells. Going for an " smooth" look with less places for dirt and rust to collect. Oh!, I've picked a color too! I decided on Dupont UreGlow Jade Metallic. ( I think I spelled it correctly) Now for the bondo and sanding...............
__________________
Henry
Yes! If you go look in the rides of the week board and look for the one for 4/10/2006, you can get a good look at it. I sent him an email and he told me the color he used. I really like it and Faye does too! In the shade, it appears to be dark, and when it's in the sun, you can see the " jewel " shine. I plan on painting the whole outside with it. But, I need an idea for the cab inside. Any ideas? It's already painted with the lighter shade that's on the upper half of my truck. Looking for a better color to complement it.
__________________
Henry
