How to static time an MSD ready-to-run distributor - Ford Truck Enthusiasts Forums
Old 05-15-2006, 04:59 PM
Squeak51 Squeak51 is offline
Squeak51 is starting off with a positive reputation.
I've wrestled with this for some time now. How do I set the static timing with an MSD distributor? With the point type distributors, you could turn the engine over until the timing mark on the harmonic balancer read whatever static timing you wanted (8 to 12 degrees's) for number one cylinder. Then you removed the dist cap and connected a trouble light to one side of the points and other to ground. Turn on your ignition (not start). Then you could rotate the dist until the light went out or came on. That was the point that he points were opening, thus collasping the coild field and firing the plug. With an MSD, of course, there are no points. Is there a method for setting this static timing with an electronic dist that is similar to the old points method?
Old 05-17-2006, 01:23 PM
OK, I called MSD. Their method is to set the timing marks on the harmonic balancer at TDC for number 1 cylinder. Mark the body of the distributor where the number one terminal on the distributor cap is. Remove the cap, align the rotor with the mark on the distributor body, reinstall the cap and snug down the distributor hold down bolt. This will get the car started and you can then use a timing light to fine tune the timing. The tech guy says that he's done it a bunch of times and it always works.
Old 05-17-2006, 07:32 PM
TigerDan's Avatar
TigerDan TigerDan is offline
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
The same should hold true for virtually any electronic ignition distributor. Your just can't really static time them like you can with points, you can just get them in the ballpark so it will run.
Very nice, clear description. Thanks!
Can you decipher this information for me? (aka help me fix my Buyerz 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-24-2014 08:09 PM
1984 300 msd ignition dilemma loksoff 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 20 12-03-2013 07:17 PM
69 F250 timing/running problems tmcalavy FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 19 01-04-2011 07:51 AM
Installing Distributor 302 fordor Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 03-18-2010 08:49 PM
starting issue with new msd distributor sdg0080 1973 - 1979 F-100 & Larger F-Series Trucks 5 02-17-2010 11:26 PM
Tags
289, 351w, cap, cylinder, distributor, ford, marked, msd, number, static, statically, time
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
