cam interchange question
Old 05-15-2006, 11:47 AM
mustangman's Avatar
mustangman
mustangman is offline
was wondering if the overhead cam from a 1991 dual plug head fit on a 1988 2.3 non dual plug head,,these motors are both from mustangs 2.3s,,heard these cams had a higher lift? more torque? thanks
Old 05-15-2006, 12:03 PM
jamnjm's Avatar
jamnjm
jamnjm is offline
I think that late model dual plug head has a roller cam in it, but it may be the modular one (slip on cam lobs).
Not for sure on the lift and duration but OldRob at www.powerbyace.com may have those facts on hand for you.
Old 05-15-2006, 03:46 PM
jamnjm's Avatar
jamnjm
jamnjm is offline
...also, mark the followers to each cam as you want to keep them in the same locations too as they break in together.
Old 05-16-2006, 11:22 AM
mustangman's Avatar
mustangman
thanks Jamnjm for the info,the motor just came in the local junk yard this weekend if its still there by next weekend i'll pull the cam off with the followers
Old 06-10-2006, 09:08 AM
jimdandy's Avatar
jimdandy
jimdandy is offline
Ranger cams are all rollers from late 88 up. All EFI 2.3/2.5L cams are interchangeable. All followers are interchangeable thru 1994. They changed the followers in 95 to fit the narrower valve stems. Followers after 95 will not fit the earlier 2.3 engine. You can mix the followers on a roller camshaft, but not on a slider follower. I have a roller and followers for sale in classifieds. jim d
Franky78
1983 - 2012 Ranger & B-Series
03-23-2011 08:52 AM
seven up
4 Cylinder Engines
18
09-10-2008 12:43 PM
gUiTo1969
03-17-2004 05:07 PM
Andysutt
19
11-18-2003 07:02 AM
aksniper
4 Cylinder Engines
01-04-2003 03:43 AM
Quick Reply: cam interchange question
