Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-15-2006, 11:47 AM
mustangman mustangman is offline
Garage is empty, add now
mustangman is starting off with a positive reputation.
cam interchange question
was wondering if the overhead cam from a 1991 dual plug head fit on a 1988 2.3 non dual plug head,,these motors are both from mustangs 2.3s,,heard these cams had a higher lift? more torque? thanks
  #2 (permalink)
Old 05-15-2006, 12:03 PM
jamnjm jamnjm is offline
jamnjm is starting off with a positive reputation.
I think that late model dual plug head has a roller cam in it, but it may be the modular one (slip on cam lobs).
Not for sure on the lift and duration but OldRob at www.powerbyace.com may have those facts on hand for you.
  #3 (permalink)
Old 05-15-2006, 03:46 PM
...also, mark the followers to each cam as you want to keep them in the same locations too as they break in together.
  #4 (permalink)
Old 05-16-2006, 11:22 AM
thanks Jamnjm for the info,the motor just came in the local junk yard this weekend if its still there by next weekend i'll pull the cam off with the followers
  #5 (permalink)
Old 06-10-2006, 09:08 AM
jimdandy jimdandy is offline
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
Ranger cams are all rollers from late 88 up. All EFI 2.3/2.5L cams are interchangeable. All followers are interchangeable thru 1994. They changed the followers in 95 to fit the narrower valve stems. Followers after 95 will not fit the earlier 2.3 engine. You can mix the followers on a roller camshaft, but not on a slider follower. I have a roller and followers for sale in classifieds. jim d
Tags
1991, 23, cam, camshaft, dual, ford, interchange, interchangeability, plug, roller
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
