Squeaking/Creaking In Front End of 2002 Focus - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 05-15-2006, 09:43 AM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Question Squeaking/Creaking In Front End of 2002 Focus
Well, I finally am having an issue with my Focus. Seems that when I am turning around corners and the weight of the car is shifting the front end has a creak/squeak in it. Last oil change (about 2 months ago) when I had the car up on the hoist at my Dad's place I checked out all the front end parts and they seemed fine.
So, within the last month or so this has become a problem. Anyone know of anything to check before I put it back on the hoist?
-Matt
Old 05-16-2006, 12:53 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
I would start by checking the sway bar end links and tie rod ends.
Can you get it to make the noise if you turn the steering and bounce the front end? If you can then touch each joint while it's making the noise. Usually the problem one will feel rough compared to the rest.
If you can't figure it out that way I'd remove the sway bar ends links and try it.
Old 05-16-2006, 11:36 AM
Beast12's Avatar
I have been reading up and am also thinking sway bar end links (connecting links). So would they be squeaking at the connections to the sway bar and also up top? Is there a way to lubricate them or just replace them? Do you think you could get me a ballpark price on the parts to replace? Canadian dollars is fine. Should be something I can do myself.
It has been raining here recently and they haven't been making much noise. If the noise comes back I will maybe unhook them and drive around and see what happens.
Thanks again Dave!
-Matt
Old 05-16-2006, 12:32 PM
loudfords's Avatar
loudfords loudfords is offline
loudfords has a great reputation on FTE.loudfords has a great reputation on FTE.loudfords has a great reputation on FTE.loudfords has a great reputation on FTE.loudfords has a great reputation on FTE.
I had same problem - mine was a broken coil spring.
I have heard about end link problems, but mine were all ok.
Do you have a pit you can drive over to check it out? Leave the front suspension loaded and start wiggling things until you find something loose, it's harder to find with the car on a hoist and the suspension unloaded.
Old 05-16-2006, 01:23 PM
Beast12's Avatar
I know about the whole issue with broken coil springs so I checked them. If they do break though there is a 10 year warranty on them. You did know that, right?
I don't have a pit. I crawled under the car and was trying to wiggle things while it was in the driveway. Kind of hard to do though. Couldn't really find anything loose. The end links move a bit but I believe they should move a little bit.
Hmmmm......
-Matt
Old 05-16-2006, 03:38 PM
loudfords's Avatar
I didn't know about warranty on the springs. My father in law and I replaced them in his suspension shop - and he didn't charge us for the parts. We also replaced the one strut bearing since it was damaged from the broken spring side-loading it. Apparently the suspension warehouse says they sell lots of strut bearings for Focuses.
My spring broke inside the rubber sleeve on the spring, so it wasn't really obvious until I was under the car and saw the spring all pushed to one side. Oh, the breaking springs seem to be more common in areas like ours that put lots of salt on the roads in winter.
Old 06-12-2006, 02:32 PM
loudfords's Avatar
Matt, did you ever find out what the problem was?
We had the ignition cylinder seize on our Focus this weekend. Found out it's not that rare. Brought the car to the dealer on Saturday, should get it back later today. The only good thing about it? The Focus has the nicest tie-down points of any vehicle I've ever hauled on the trailer!
Old 06-12-2006, 05:38 PM
Beast12's Avatar
No, I didn't. Seems the problem has kind of gone away.
You never knew about the ignition cylinder seizing problem? Wow! I have heard about that lots of times. I would be interesting in knowing what that costs to fix (if you don't mind me asking). Make sure you have the updated cylinder (you should).
-Matt
Old 06-12-2006, 06:00 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
Matt, the easiest way to fix them squeaks is to turn the volume on the radio up, then you don't hear them anymore!!
Old 06-12-2006, 06:26 PM
Beast12's Avatar
Well, my radio was being kind of stupid so I wasn't using it and that is when I noticed the squeaks. Now may radio is fine and they are gone. Sooooo, maybe they are still there?
-Matt
Old 06-13-2006, 12:29 PM
loudfords's Avatar
Came to 265. Rather high labour rate at this dealer. Yeah, it's the updated cylinder, should never happen again. At least they can match the cylinder to the keys for the car so they don't need to be replaced. (chip = $$$)
I haven't really done any Focus problems research since we bought it, just before. Now something will happen and THEN I find out it's common. So far:
-ignition cylinder
-AC needed recharge (undetectable leak though, which we were happy about)
-broken coil spring
-EGR sensor
-trunk button doesn't work
Kind of annoying to be always doing little things every year on the expensive vehicle, when my 79 just needs a couple oil changes every year.
Old 06-13-2006, 08:37 PM
Beast12's Avatar
Yeah the trunk thing is common as well. It's because you need to use the key more often.
I haven't had any problems yet *Knocks on wood*.
-Matt
Old 06-13-2006, 10:40 PM
rywegh's Avatar
rywegh rywegh is offline
rywegh has a good reputation on FTE.rywegh has a good reputation on FTE.
uhhh Matt since you quit working for your dad... have you weighted yourself lately??? Especially if you just the springs and the front end parts were good.
Old 06-14-2006, 06:21 AM
Beast12's Avatar
Hmm...that's right. Since I quit working for my dad climbing trees (almost a year ago) I know I have put on 15 or so pounds. Maybe I should see what the front end is rated for. Maybe look into getting the Snow Plow package?
-Matt
Old 06-18-2006, 10:51 AM
Beast12's Avatar
I changed to oil on the car this weekend and had it up on the hoist at my Dad's house. I could not find anything that was wrong. I also (with the radio off) did some quick cornering and didn't hear any squeaks or anything. So, I guess I will leave it until they come back?......
Quote:
I made sure to look for those when I was under there. VERY NICE! Too bad I will never need them.
-Matt
99 EB Creaking/squeaking noise from front passenger side?? KJR05 Expedition & Navigator 4 03-01-2014 11:36 AM
creaking/squeaking noise front end aetksmith Excursion - King of SUVs 6 01-31-2011 10:53 PM
Squeaky 2001 Escape XLT Jessiesage9 Escape & Escape Hybrid 3 07-05-2007 10:16 AM
98 explorer front end squeaks and creaks:( rustyolred27 Explorer, Sport Trac, Mountaineer & Aviator 7 03-25-2007 01:02 PM
explorer suspension creak milmo1 Explorer, Sport Trac, Mountaineer & Aviator 4 03-08-2005 05:51 PM
Tags
2000, bar, chip, corner, cornering, creaking, end, focus, ford, front, frontend, link, noise, squeal, squeeks, sway, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
