burning oil
burning oil
have a 1984 2.3 ranger whin i rebuild it redid the pistons with new rings new pistons new bearings [the works ] had head redone but it still use oil can anyone tell me what might be going on put new pvc value on it .it has a two barrell carb no vaccum lecks that i can hear please help im woundering if the head might be bad .but i had it rebuilted. thanks
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
on
Did you have the engine bored out and installed oversize pistons, or just put new pistons in the original bores? How were the cylinders honed? And what kind of rings were used, moly or cast? Moly rings in original bores often won't seat properly, and a different honing procedure is required for them is the reason I ask.
Also, it's fairly normal for new rings to take a little while to seat properly. How many miles since the rebuild?
He's talking about putting it in 4th gear, at about 30-40, flooring the gas pedal 'til you get to about 60-65, and then letting it coast down in gear until you are back at 30-40. THis will push the rings hard (flooring) against the cylinder walls, yet keep the RPMs within reasonable (high gear) range. Rinse and repeat about 10 times.
I'd be checking that the work on the cylinder head included installing valve guide seals. If they were forgotten, or the valves really loose in the guide, you'd get blue smoke almost all the time. Is it possible the valve stems were oversized and someone installed standard size? Unless I do it myself, ya know.
When you installed the pistons, did they slide into the cylinders with some resistance? What is some? Well, I have had to use the handle end of a hammer to push them down to engage the connecting rod with the crankshaft. It wasn't just the palm of my hand. Are you sure you got oversized rings? Does the thing have enough power to get out of its own way, or is it really slow? Incorrect rings would alllow so much blowby, and would probably have so little compression ... probably hard to imagine it would run.
tom
tom
burning oil
yes thanks you for your reply the engine has a lot of power.will try what you or telling me about puting drag on engine .had head rebuilted.but this is the second block that i have used both rebuilbs smokes both had power i am beginning to think it is something to do with the head. i think i wil change the head out with another to see if that might stop it smoking thank you so much for your help. lardon
