Intermittent wiper weirdness *HELP* - Ford Truck Enthusiasts Forums
Old 05-14-2006, 06:17 PM
fozzy's Avatar
fozzy fozzy is offline
fozzy is starting off with a positive reputation.
So I have the intermittent wipers. The work fine on low, high, wash.....but on intermittent they just stay on slow speed. They quit parkking years ago, so I just time it just right at bottom of stroke.
Now they were staying on even with switch off!! So I picked up a working switch assembly set from a donor (with the black box thing) replaced, and still same problem!!!
If i even turn the key on, they are on low always. Occasionally they work correctly while I am watching them. I grounded motor, switch but still no luck
WHat does a guy have to do to have working wipers!! I have thoroughly cleaned all contacts inside the first switch to no avail.
Is this a ground issue? PLease help
PS It is a 1977 FORD RANGER XLT 2WD.
Old 05-14-2006, 06:38 PM
n9lhm n9lhm is offline
n9lhm is starting off with a positive reputation.
It's the motor. There is a sensor in the motor to tell it when the wipers are at the end of the stroke, and it evidently doesn't think that it ever gets there. Try a different motor. Brian
Old 05-14-2006, 07:02 PM
fozzy's Avatar
Darn, now have 2 intermittent switches, boxes..... Can this be fixed internally? Or should I just try a replacement? DO they have these new at autozone or something?
I am an electrician and I am handy at rebuilding contactors etc, is that too much trouble?
Thanks for input, Please reply
Old 05-14-2006, 08:55 PM
If you've had a motor apart before, sure, alignment mark the case and take it apart, you can't make it work any worse than it already does right? If you have knowledge of motors and basic electricity it should be pretty much intuitive, it's just a DC motor and a switch. Dennis Carpenter lists the motor for $230 and LMC has the good replacement motor for $299 and the overseas replacement for $90, so it might be worth fixing it yourself. Let us know what you find. Brian
Old 05-14-2006, 09:14 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
It's usually a bad motor ground that causes the problem.
What coding is on the governor box ?
C7T? -?????
Old 05-14-2006, 09:26 PM
fozzy's Avatar
well, autozone has new wiper motor for $51+ tax. It is probably not OEM, but it has lifetime warranty.ARe you talking about that little black box? It is Motorcraft "17C476-" and then there is D3TB AA 260 6 K 26 and then a big "2".
The other one from the donor truck has a different number all together. I noticed it had one less wire in the harness then my original (?).
I would like to use my original switch because I opened it and cleaned it all up, it operates very smoothly.
Is the motor grounded through the bundle of wires coming from the motor? There are four wires I believe. Or is it grounded by it's mounting to the metal?
Any thoughts?
Old 05-14-2006, 09:33 PM
That governor is too old for that year truck.
You need the D6TB governor.
There could be problems with the wiper parking mechanism.
It may need replacing.
Have the wipers been acting up before this ?
Old 05-15-2006, 12:57 AM
fozzy's Avatar
Yes, I cant remember the last time they parked correctly. I would reach under the dash and push on all the wires and they would park!! I have cleaned all the plugs down there, all harnesses, and it is still like this.
The replacement switch I have has some different numbers, I noticed. This one I replaced should be the original part. I bought this truck 14 years ago from the man who had it new. I have every receipt, even the window sticker. I cant imagin him having probs with it. If I remember right, it worked for the first 5 years I Had the truck.
Old 05-15-2006, 03:48 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Dennis knows those wiper systems forwards and backwards. He should be able to help you thru this.
Old 05-15-2006, 08:23 AM
fozzy's Avatar
Ok, Where is Dennis when you need him??
Old 05-15-2006, 01:13 PM
I'll be right over
I suspect it may be the ground wire where it enters the motor.
Try dis-connecting the wipers from the motor and see if the motor "will park normally"
Old 05-15-2006, 02:04 PM
fozzy's Avatar
How would removing the wipers affect the ground entering the motor? Which wire is the ground? My shop book shows 4 wires for intermittent, and 3 for non int... It just shows a ground symbol from motor body, but no actual ground lead.
you mean mechanically disconnect the wipers from the shaft?? Or electrically disconnect the switch while running? I dont understand.
Old 05-15-2006, 02:11 PM
Mechanically, so there isn't any interference trying to do the electronical thing
I think the black wire is ground
EDIT:
Schematic
http://www.clubfte.com/users/mil1ion/wipercircuit.jpg
Old 05-15-2006, 02:18 PM
fozzy's Avatar
Ok, Your showing me a schema of the switch and governor, but you want me to remove the wipers from the wiper motor, right??
Just want to make sure.
THANKS a bunch for helping me out. I have the interior completely removed, and a fresh coat of urethane primer, and I want to fix all these little probs while It is in this stage.
Please reply
Old 05-15-2006, 02:36 PM
Jiust wiggle them around a little with key on.... wiper switch active...then put switch in Park and see what happens.
Don't be surprised if the switch is the problem.
It happen when one mixes different years of parts.
Here is the troubleshoot info.
Need help with windshield wipers southtexasidi 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 12-16-2014 10:28 AM
Wiper problems?? baverwolf 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 10-02-2011 10:29 PM
Wiper Motor Stays On Monzter Kuztomz 1999 to 2016 Super Duty 17 07-18-2011 12:18 PM
Intermittent Wiper conversion? 80s Trucker Electrical Systems/Wiring 9 07-18-2009 09:23 AM
88 F-250 Wiper Problems rusty88f250 1987 - 1996 F150 & Larger F-Series Trucks 2 02-23-2008 10:35 AM
Tags
1977, 1992, 1995, d3tb, f150, f250, ford, governor, intermittent, problems, ranger, switch, trouble, truck, trucks, wiper, wipers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
