5.4 reliability - Ford Truck Enthusiasts Forums
5.4 reliability
Old 05-14-2006, 05:58 PM
capstan capstan is offline
capstan is starting off with a positive reputation.
5.4 reliability
I used to tow my 7000 lb sailboat with a 351H.O., and c-6 trans at 70 MPH with no problems. But I had to get rid of it, because everything underneath was rusting out.
I'm looking for a used E-150 van, 2000 or newer, with a 5.4 to tow the sailboat to florida this winter. But I have heard of the 5.4 blowing plugs, and having head gasket problems. Is this a major problem, or just a few engines. What years would be more reliable, between 1998, and 2003. I try to avoid a new engine, the first few production years.
I currently have a 95, E-150, with a 302, but it doesn't have the power to pull the sailboat. I miss my 351!
Old 05-14-2006, 08:25 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
You'll get more opinions about this I'm sure...
Spitting plugs, there's a few more 5.4's doing than V10's, but it's still rare.
The head gasket problem was taken care of, I think it was the head or block not so much the gasket.
Get a 2003 if you can, the later the better (for obvious reasons).
The vans usually come with 3.73, see if you can find one with more gear, you're going to need it with the 7000lbs to tow it comfortably.
(Caveat: Most of the above I learned about here, I don't have a 5.4 or an E-series
Some people will tell you you need the V10. If you're going local, the 5.4 is going to do fine.
Old 05-14-2006, 08:47 PM
kspilkinton's Avatar
kspilkinton kspilkinton is offline
kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.
The 2v 5.4 is a stout motor with a few flaws that got worked out as the design aged. I'm not too keen on the 3v version, but as we can see here... not too many people are reporting problems on an engine that is now 2 1/2 years old.
My only issue with the towing aspect is the GCWR... I see too many people towing too heavy a load for their trucks and wondering why they blow transmissions and run through brakes. Vans are heavier than trucks so the towing capacity drops. A fully loaded E150 with the 5.4 will not tow 7000# and be "cool" about it. It's not the engine that I'd be worried about, but the rest of the drivetrain, suspension, and brakes...
-Kerry
Old 06-08-2006, 06:41 AM
NHguy NHguy is offline
NHguy is starting off with a positive reputation.
The no trouble one-to-get is the 3 valve that has the later head and 100 k plugs, plus if you can get the 4R75 trans (don't know how they are spec'd) there is a thread stating the 75 has beefier internals.
Many people on there are complaining about the plug blow out issue. On the other hand, if someone has a solid van with the blow out issue I bet you can buy it for short money...the repair does not require head removal, it just takes some mechanical aptitude. There is a really good series of posts in there on how to deal with it. I would think the main issue with a van is accessing the plug hole. Posts in the forum seem to indicate that #3 on the right side is the most common blow out. Before the blow out people think the have a lifter noise or manifold leak but it's actually the plug hole "breathing"
Good luck
Old 06-13-2006, 12:40 PM
highboy390fe highboy390fe is offline
highboy390fe is starting off with a positive reputation.
I have a 98 e250 work van with the 5.4 and we have been pulling an enclosed trailer with it for 50,000 miles at least and it has held up fine. It now has about 150,000 on it and we still are pulling hard.
Old 07-03-2006, 06:51 PM
BLK94F150 BLK94F150 is offline
BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.
I was 100% pleased with my 2000 F150 5.4 until it blew a head gasket at around 77000 miles. Way to young IMO.
My two pennies is get the V10 in an E250. You won't have that much worse mileage. Towing anything drops my mileage to around 10-13 MPG. That's with a 16x5.5 tailer, 600lb mower, weed eater, backpack blower, and 2 guys. In short, not that much weight.
Mike
Hey Ya'll HappySailor New Member Introductions 5 12-09-2014 12:12 PM
To Buy or Not To Buy? 2000 4x4 F250 $2,200 (bought, now rebuilding timing chain and oil pump) SCF250 1999 to 2016 Super Duty 74 02-09-2012 09:42 PM
Redneck Roadtrain Fullcrew7.3 Manitoba / Saskatchewan Chapter 20 07-24-2011 02:46 PM
Going to tow a sailboat, how do I get Aero ready? cowgirlmechanic Aerostar 18 07-14-2005 03:33 PM
4x4 w/manual T-Case? tmdata Ranger & B-Series 4 12-12-2004 01:37 PM
Tags
06, 2001, 54, cai, e250, engine, f150, f250, ford, gasket, head, reliabilety, reliability, reliabilty, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
