what 2bbl to use on a 6 cylinder - Ford Truck Enthusiasts Forums
Old 05-14-2006, 03:35 PM
crm318 crm318 is offline
crm318 is starting off with a positive reputation.
i have a 223 that will have a header and a clifford 4bbl intake. i want to use a 2bbl carb and an adapter plate. what would be a good carb for the job? ive been looking at 2100s, autolites, and rochesters. what do yall think?
Old 05-14-2006, 05:59 PM
200000+F150 200000+F150 is offline
200000+F150 is starting off with a positive reputation.
Some would call it blasphemy, but I think you can't hardly go wrong with a Rochester 2GC. Plentiful, cheap, dependable and efficient. About a billion in the junkyards that nobody wants. $15 kit and you're good to go for about 10 years....
Old 05-15-2006, 02:28 AM
Col Flashman's Avatar
Col Flashman Col Flashman is offline
Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.
The Rochester 2GC is a good choice, but I've always prefered the Holley over all others.
Old 05-16-2006, 08:28 AM
blackgtstang blackgtstang is offline
blackgtstang is starting off with a positive reputation.
I used a Holley 500 on my 86 300. Works great, truck runs like a beast!
Old 05-16-2006, 08:48 AM
Pkupman82's Avatar
Pkupman82 Pkupman82 is offline
Pkupman82 has a good reputation on FTE.Pkupman82 has a good reputation on FTE.
I use a Holley 2300 (350 cfm) 2bbl on my 84 300, more power and easier on fuel than the 1bbl.
Old 05-17-2006, 09:22 PM
broke77f100 broke77f100 is offline
broke77f100 is starting off with a positive reputation.
why not just use a 4 bbl carb?
Old 05-18-2006, 01:45 AM
its a totally stock 223. i dont know if it could handle a 4bbl in its current condition.
Old 05-18-2006, 05:49 PM
oh ok i see ur point
Old 05-18-2006, 07:29 PM
shmoozo shmoozo is offline
shmoozo is starting off with a positive reputation.
Quote:
Actually that shouldn't be a problem so long as the 4 barrel carb is one of the usual vacuum secondary units that has been properly selected and set up and correctly tuned for your application. Keep in mind that the vast majority of the time the engine will only be using the smaller primaries when you're driving around town and generally speaking those are roughly comparable to a modest 2 barrel carb. It's only when you get on it pretty good and hard that the secondaries would open at all, and then only in response to demand.
One possible choice would be the same old Holley 390 CFM carb that so many folks use on their Ford 300's. You might need to make some tuning changes to it to get the best combination of performance and fuel economy, but Holley carbs are pretty common so tuning parts and expertise with them are fairly easy to come by.
On the other hand one of the garden variety 2 barrel carbs like any of the models others here have suggested could also work quite well, assuming it was properly tuned to work well with your particular engine. (Note that at least some amount of carb tuning and set up is likely to be needed no matter what kind of carb you use.)
One unorthodow suggestion I could toss into the mix would be a Quadra-Jet carb. (I can almost hear the shrieks of "BLASPHEMY!" as I write this. ) The Quadra-Jet carbs have the advantage of having very small primaries. That means that your engine could get fuel economy and low-end throttle response of the sort it would get when using a small two barrel carb, but would have plenty of 4 barrel "oomph" when you stomped on the gas because the secondaries would open as needed to increase the amount of air flowing into the engine.
As with any carb you'd need to get it tuned to work with your specific application, but that shouldn't be too difficult. Q-Jets may be less common than Holleys, but they still have a sizable following. Click HERE to see an article that discusses Quadra-Jet carbs. HERE'S a link to another article about them.
Old 05-19-2006, 08:02 AM
Red2003XLT Red2003XLT is offline
Red2003XLT is starting off with a positive reputation.
Any intakes that take the spread-bore and fit the 240-300?
Old 05-19-2006, 09:48 AM
Quote:
All you need is a standard 4 barrel intake and an inexpensive adapter. The Clifford intake for the Ford 223 along with their standard 4 barrel adapter and a Quadra-Jet to Squarebore 4 barrel adapter will allow the Quadra-Jet to mount quite easily.
By the way, Quadra-Jets have a reputation for being able to operate properly at far more extreme angles than Holley carbs, which makes them a good choice for trucks that will be used offroad.
Old 05-21-2006, 12:49 PM
I found another useful link to a web page with a lot of links to web pages full of various kinds of info about Quadra-Jet carbs. Some of the links on the page have expired, but a lot of them do still work.
Quadra-Jet carb links page
Also, you may recall that I mentioned that Quadra-Jet carbs have really small primaries, and I found an image that illustrates this fact pretty well. It's a picture of a stripped down throttle body plate from the bottom of a Quadra-Jet carb and you can really see how small the primaries are compared to the secondaries in this image. For reference, the two smaller round holes at the top are the primaries, and the two larger round holes directly below them and partially covered by the jaws of the vise are the secondaries. Here's the link to that image:
Quadra-Jet throttle body plate in a vise
That image is from an article on the Car Craft web site. Here's a link to that article.
Quadra-Jet
Old 05-21-2006, 02:06 PM
N7ghtwolf N7ghtwolf is offline
N7ghtwolf is starting off with a positive reputation.
Quote:
Would a 2bbl really be easier on fuel than a 1bbl or a 4bbl?
Old 05-21-2006, 02:52 PM
Quote:
That depends on a lot of factors including the types of the intake manifolds used, the specific ways the carbs have been tuned, which carbs are used, etc.. There's no single correct answer to that question.
Old 06-14-2006, 03:54 PM
jlm_1962 jlm_1962 is offline
jlm_1962 is starting off with a positive reputation.
adapter plate
which adapter plate should I use to put a two barrel holley 500 on a 300 6 cyl. summit and trans adpt offera couple different sizes
What is the correct "factory" 4bbl intake and carb? Mudshovel_009 1967 - 1972 F-100 & Larger F-Series Trucks 23 02-05-2017 01:36 AM
Ford 302 - 2bbl to 4bbl conversion questions Rusty_S Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 06-22-2016 07:52 AM
4bbl vs 2bbl chefcharles 1967 - 1972 F-100 & Larger F-Series Trucks 1 12-09-2014 12:11 PM
FE intake bigfoot22 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 37 01-22-2012 10:28 AM
2bbl to 4bbl big block power FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 15 05-10-2002 01:12 AM
Tags
1970, 250, 2bbl, 2gc, 300, adaptor, bbl, carb, cyl, cylinder, eng, ford, kit, mustang, picture, stripped
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
