what 2bbl to use on a 6 cylinder - Page 2 - Ford Truck Enthusiasts Forums
Old 06-14-2006, 07:04 PM
opus's Avatar
opus opus is offline
opus is starting off with a positive reputation.
On a stock intake/exhaust setup, do you think adding a 2 bbl would be worth it?
Old 05-18-2014, 10:32 PM
Gayle B Gayle B is offline
Gayle B is starting off with a positive reputation.
what throttle cable to use when installing a holley 2bbl on my f250 300 six
Old 05-19-2014, 10:40 AM
1986F150six 1986F150six is online now
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Welcome to the forum, Gayle B!
Depending on whether or not you are mounting the carburetor by using an adapter [2/1] or replacing the intake manifold with an aftermarket one [i.e.Clifford, Offenhauser] and what year your truck is, you might be able to use the original cable or some have found a longer stock cable [for a V8]? Others use a LOKAR cable found @ parts stores. They come in different lengths.
What is the correct "factory" 4bbl intake and carb? Mudshovel_009 1967 - 1972 F-100 & Larger F-Series Trucks 23 02-05-2017 01:36 AM
Ford 302 - 2bbl to 4bbl conversion questions Rusty_S Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 06-22-2016 07:52 AM
4bbl vs 2bbl chefcharles 1967 - 1972 F-100 & Larger F-Series Trucks 1 12-09-2014 12:11 PM
FE intake bigfoot22 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 37 01-22-2012 10:28 AM
2bbl to 4bbl big block power FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 15 05-10-2002 01:12 AM
Tags
1970, 250, 2bbl, 2gc, 300, adaptor, bbl, carb, cyl, cylinder, eng, ford, kit, mustang, picture, stripped
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
