How to rejuvinate rubber seals? - Ford Truck Enthusiasts Forums
Old 05-14-2006, 04:05 PM
Raptor Raptor is offline
Raptor is starting off with a positive reputation.
What's the best products / methods you've for rejuvinating rubber door seals, etc?
Old 06-13-2006, 02:43 AM
Dr. Detail Dr. Detail is offline
Dr. Detail is starting off with a positive reputation.
Hi
The best I've found is Meguiars #40 Vinyl/Rubber Cleaner/Protectant. It's a great penetrant for rubber. You can put it on your tires and watch it soak in. I like to spray it liberally on to rubber parts and let it soak. They look like new and live a lot longer. You can also cut a sponge in the shape you need to apply it just to the part and avoid the paint. It won't hurt paint but why go there?
Visit my website for more info and products www.drdetailforless.com
Thanx for listening
Old 06-13-2006, 12:30 PM
Rosie Rosie is offline
Rosie is starting off with a positive reputation.
How about tire rubber cleaner? If it works on your tires why wouldn't it work on rubber door seals? Just spray on the cloth you plan to use and rub the cloth on the seals. This way the tire spray will go where you want it. Make sure the rubber seals are clean first before applying the protectant.
Old 07-13-2006, 05:11 PM
Frrt's Avatar
Frrt Frrt is offline
Frrt is starting off with a positive reputation.
I tried silicone spray on my weatherstripping and it seemed to have treated them well....then I looked at the rag and saw my reef blue paint on it. ouch. i'll go back to a thin layer of vaseline or something
Old 07-13-2006, 09:25 PM
wickymustang wickymustang is offline
wickymustang is starting off with a positive reputation.
So does tire shine, the stuff that makes the tires all shiny and wet looking protect the rubber at all or no? Cuz I've heard a few guys use it on their tires and all other rubber and seals.
Old 07-13-2006, 09:44 PM
Sparky6 Sparky6 is offline
Sparky6 is starting off with a positive reputation.
I use Adamís V.R.T it's water-based, and contains no harmful solvents, silicone or alcohol. They have V.R.T in& out spray too!
Old 07-20-2006, 11:09 AM
TNTi TNTi is offline
TNTi is starting off with a positive reputation.
Had a leaky sun roof one time and a shade tree mechanic told me to put glycerin (sp?) on the rubber seal. It worked like a charm.
You can buy the stuff over the counter at any drug store.
Old 07-20-2006, 07:11 PM
ford_mudd_runner ford_mudd_runner is offline
ford_mudd_runner is starting off with a positive reputation.
i work at a detailing shop and we use out tire dressings on everthing rubber and any black rubber trim. works grate ,shines nice and if any dirt is stained on it the dressig hides it very well.
you probley cant get the tire dressing we use but you could probley use any tire dressing.
Old 07-21-2006, 09:34 AM
TruckDaddy TruckDaddy is offline
TruckDaddy is starting off with a positive reputation.
The best thing to use is dielectric grease, seriously. You can get a little tube of it at any automotive store. Many of my Corvette brothers use it as well as I.
Old 07-21-2006, 01:43 PM
furball69's Avatar
furball69 furball69 is offline
furball69 has a very good reputation on FTE.furball69 has a very good reputation on FTE.furball69 has a very good reputation on FTE.
Quote:
Vaseline is a petroleum product; I wouldn't use it on any rubber pieces.
Crew Cab Interior Rejuvination Project dilan73 1999 to 2016 Super Duty 190 12-30-2013 09:19 AM
pcm rubber firewall seal bigbubba87 1999 - 2003 7.3L Power Stroke Diesel 2 01-08-2012 06:52 AM
79 f250 custom 300 six cyl oil pan leaks 4rdnut 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-30-2011 02:38 PM
windshield rubber seal armstrongfordtrucks 1973 - 1979 F-100 & Larger F-Series Trucks 2 05-06-2007 12:56 PM
Transmission Fluid Additives Piffery1 Clutch, Transmission, Differential, Axle & Transfer Case 0 11-14-2005 01:22 AM
Tags
compatible, detailer, door, gaskets, hurt, lubricate, protectant, pure, rejuvinate, rubber, seal, seals, silicone, spray, sunroof, trim
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
