difference between e4od and 4r100 - Ford Truck Enthusiasts Forums
Old 05-13-2006, 04:17 AM
jerrytown2001's Avatar
jerrytown2001 jerrytown2001 is offline
jerrytown2001 is starting off with a positive reputation.
What exactly is the difference between a e4od and 4r100 transmissions? I have a e4od repair manual. What will I need to rebuild a 4r100?
Old 05-14-2006, 12:19 PM
jtharvey's Avatar
jtharvey jtharvey is offline
jtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to all
I don't know, I just don't like to see a thread with 0 replies on page 3 - trying to bump it up.
Old 05-14-2006, 04:31 PM
cangim's Avatar
cangim cangim is offline
cangim is gaining momentum as a positive member of FTE.cangim is gaining momentum as a positive member of FTE.
Pretty much just the name. The 4r100 is an e40d transmission. The only difference is depending on what year your transmission was made. If you have an E40d repair manual you will be good to go for most everything, you might also want to get a revisions update as that is where the differences will be. I found that I referenced my revisions manual more than the repair manual when I rebuild mine. Some of the parts that have been updated replace obsoleted parts, so depending on what you replace you may have to replace the complimentary part as well.
Check out Suncoast.com and brianstruckshop.com for some more info. If you are going to rebuild it your self, I suggest transgo HD/2 repro kit, Eagle Red alto clutches and Kolene steels. From the research I did, sounded like they are the best, and the top two tranny repair shops mentions frequently here use them as well. I ordered all my stuff together including a triple disc converter for 1200 from transmission exchange. So far I am very happy, didn't realize how much the dang thing slipped prior to the rebuild.
Old 05-14-2006, 05:10 PM
BuickTurbo's Avatar
BuickTurbo BuickTurbo is offline
BuickTurbo is starting off with a positive reputation.
4R100 is an updated E40D. That's all I know at the moment.
Old 07-07-2006, 10:49 PM
SVLERF250PWRSTRKE's Avatar
SVLERF250PWRSTRKE SVLERF250PWRSTRKE is offline
SVLERF250PWRSTRKE is starting off with a positive reputation.
would a E40D fit in a 4r100's place in a 2000 f250 pwrstroke?
Old 07-08-2006, 09:12 PM
cangim's Avatar
Quote:
Yes it would fit, the only difference is that the 4r100 has some updates from the E4OD, otherwise they are the exact same. The Solenoid connector plug may be a little different on outer housings. Do you have a spare E40D that you want to put in? or just thinking?
Old 07-09-2006, 02:26 PM
ramsmoker's Avatar
ramsmoker ramsmoker is offline
ramsmoker is starting off with a positive reputation.
Smile trans
I did a E4OD over the winter and the parts kit said 4R100. I haven't had my 4R100 next to it to see if its only the plugs. I have had the valve bodys side by side and that all looks the same. Kind of like a C6 with overdrive and electronics.
Old 07-09-2006, 04:53 PM
cangim's Avatar
It is just the ouside casing or cover to the plug. The actual pin layout of the plug is the same.
Old 01-17-2017, 09:30 AM
Bronco420 Bronco420 is offline
Bronco420 is starting off with a positive reputation.
Hi everyone I just had a quick question I have a 96 Ford Bronco with a 5.8 liter with a E4od transmission 4x4. My question is a buddy of mine has a 2000 Ford 7.3 powerstroke that I was wondering about swapping out with my 5.8 liter will I have to change the transmission out or will I be able to put it right up to the original transmission.
E4OD/4R100 hotrodfeguy 1999 - 2003 7.3L Power Stroke Diesel 2 02-04-2017 12:05 PM
E4OD vs. 4R100 10strokin 1987 - 1996 F150 & Larger F-Series Trucks 21 10-27-2015 12:18 PM
Diesel e4od dipstick same as 4r100? Brant Bowrifle Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 06-18-2011 01:46 PM
What is the diffirencein E4OD and 4R100 dinikin 1994.5 - 1997 7.3L Power Stroke Diesel 1 02-10-2007 12:30 PM
solenoid pack difference e4od and 4r100 yellow_jacket Clutch, Transmission, Differential, Axle & Transfer Case 2 10-20-2006 08:00 PM
Tags
4r100, difference, differences, e40d, e40drepair, e4od, e4od4r100, eaglered, ford, identification, manual, trannys, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
