what's the stock rear end of a 1950 F1?
Old 05-12-2006, 08:43 PM
Vee's Avatar
Vee
Vee is offline
anybody know the stock rear end of an early 1950 F1. I have what looks like a spicer, but the only number on it is "53" and it's in the model number location
Old 05-12-2006, 09:40 PM
3Mike6's Avatar
3Mike6
3Mike6 is offline
Would you please phrase your answer in the form of a question?
Old 05-12-2006, 10:07 PM
Vee's Avatar
Vee
Vee is offline
is this the stock rear end? the frame has some mods so I wasn't sure if this was the original. do you know if it's worth keeping, or should i swap it out for something else. i couldn't find any info on a spicer 53
Old 05-13-2006, 02:50 AM
51ford fan's Avatar
51ford fan
51ford fan is offline
I installed a 69 F150 3.23 in my 51F1 good swap I really like the later unit they are much stronger and parts are available. The link below has a lot of information on the swap its a direct bolt in.
https://www.ford-trucks.com/article/...ial_Swaps.html
Rod 51F1
Old 05-13-2006, 09:22 AM
al37ford's Avatar
al37ford
al37ford is offline
To answer the question, it should be a Dana/Spicer 41 as also used in Jeeps. My '49 is same & its a 3.73 ratio behind a H.O. 302 & AOD. Its held up just fine over 7 years . The link shown in the previous post is great & shows a photo of the backing plate for ID.
Old 05-14-2006, 07:59 PM
rhopper's Avatar
rhopper
rhopper is offline
My 48 has the stock dana 41 with a 4.27 ratio. Want it? It needs a good home.
1950F2
11-05-2016 10:21 PM
moose79
04-08-2016 08:35 PM
edjoe1950f1
03-18-2015 05:22 PM
Chris 56 f6
04-18-2014 09:38 PM
Skirouled!
07-15-2011 04:16 PM
Quick Reply: what's the stock rear end of a 1950 F1?
