You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hmmm...no action in the IDI forum. Lets slide this one down to the BioD forums and see if we can get you an answer.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
I've been using Biodiesel in 9 different diesels with IDI and without for over 2 years now and not one fuel related problem yet. Just remember to change out any natural rubber fuel lines and change your fuel filter early after changing to B-20 or higher.
FABMANDELUX.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
I've got a 1992 idi which I have run many tanks of bio diesel in the last 14 months. just change your fuel filter soon after switching. as for the natural rubber lines, they should be ok as long as there is no considerable seepage so that the stuff gets on the out side and eats away at it. I use either B 50 or less made out of waste vegetable oil. If you can get stuff made out of soy oil, that would make it burn better. if your idi is not turbo'd, it will not burn the bio diesel as good cuz it takes more oxygen and boost to burn that stuff.
I think you are right the reason BD tends to burn cleaner is because it is oxygenated while petrol diesel is not.
Does this mean we can look forward to diesel regulations that require oxygenation much like we did over the last 15 years with gasoline in California? I sure hope not but I can see it coming.
If corn (ethanol) is the answer to gasoline oxygenation, then maybe soybeans (biodiesel) is the answer to diesel oxygenation.
BD is more environmentally friendly than Petro for several reasons. Even B2 shows reduction in CO and CO2. Pure BD is CO2 neutral in that all of the CO2 released was initially removed from the atmosphere by the plants that produced the oil seed crop.
Additionally BD is biodegradeable at about 3X the rate of Petro so spills are less problematic
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
It would not supprise me if oxygenated diesel will be the next thing refineries will have to content with once we they have made it over the ULSD (Ultra Low Sulphur Diesel) hurdle later this year.
