Bad shake going into first - Ford Truck Enthusiasts Forums
Old 05-11-2006, 10:30 AM
Ranch57 Ranch57 is offline
Ranch57 is starting off with a positive reputation.
Exclamation Bad shake going into first
so i have a '57 ranchero 312 v8, and i just put a t-10 trans into it. changed the front Ujoint, i have a 9'' rear end, need to get the gear ratio for you. so getting into first it gives a nice shake, i can hear my bed jumping. so i lifted the rear end and put it through every gear with no shake. i dont know what it is. so to get into 1st i almost have to dump the clutch. any suggestions. i used to have a 3sp with oversdrive in it.
Old 05-11-2006, 06:37 PM
Jimbare's Avatar
Jimbare Jimbare is offline
all alone in the world
Jimbare is gaining momentum as a positive member of FTE.
is it shaking when you first take off? or is when you down shift into first?
if it is when you take off, the clutch and pressure plate need to be replaced.
if it is when you down shift into first, sounds like a bad gear in the tranny to me.
Old 05-11-2006, 07:08 PM
my pressure plate huh? needs to be replaced or just adjusted? if its replaced that means i have to take the trans back off and replace it huh? well another project it looks like.
mysterious shaking theredneckrussian 1987 - 1996 F150 & Larger F-Series Trucks 0 11-22-2013 06:21 PM
Truck shakes above 25mph Skandocious 1987 - 1996 F150 & Larger F-Series Trucks 71 04-23-2012 05:04 PM
F250 Shakes Really Bad Between 57-63 MPH bringles 1999 to 2016 Super Duty 5 02-15-2012 04:57 PM
Shaking problem JoggingGuy Ranger & B-Series 24 06-15-2005 09:38 PM
Shake in front end Twist 1999 - 2003 7.3L Power Stroke Diesel 12 09-24-2002 01:20 PM
Tags
2011, clutch, dakota, downshift, end, f150, gear, rear, release, shake, shakes, shaking, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
