smokeing ranger
smokeing ranger
I just bought a 1989 4x4 ranger with the 2.3 L that smokes bad and uses oil like crazy iam thinking i need to rering it but is there any thing else that could cause it. or is there any thing out there that can make it stop i'v used marvel mystery oil, lucas upper cylinder lube, RESTORE, does any thing work so i dont have to tear into the motor?
i havent done a comparsion check yet and its got 170000 miles on it ive replaced the pcv valve like 100 miles ago before i bought it it set all winter win i got it the first thing i did was cahnge the oil and filter air filter pcv spark plugs and wires anti freze and the all the tranny and differental fluid so at first i was think the rings were gummed up but that was like a month ago and ive put like 500 miles on it so do i need to re ring it or what?
I like Bills check the compression thought.
How did the old plugs look, were they oil soaked????
Does it just smoke after, say a all night sit & a morning start up???? If so suspect valve guides or seals
Or does it smoke after you've gotten off a long off ramp, or gone down a long hill with the throttle closed, then back on the gas???? If so suspect worn rings, so the compression check should tattle on them.
Or does it just smoke all the time???? In which case it might be this engine is just plum TARD, you know wore out, just like pawpaw!!!!! LOL
Anyway the compression check, read the plugs & think about how/when it's smoking, should help figure out what's wrong.
Let us know what you find.
BTW, any signs of an external oil leak????
**there are no miracles in a can that replace worn metal
It may need to be bored. For the work required, yank the engine, put it on a engine stand, disassemble, then mic the bore and pistons. If you're not sure how to mic a cylinder bore, get a buddy that knows what to do over to your place. You will want to mic each cylinder in multiple places to look for taper as well as out of round. Pistons will needed to be miced in multiple places too. Finally, if you are lucky enough to get by without havong to bore the block, don't forget to cut the ridge before putting it back together.
*You might consider just buying a rebuilt long block or a used engine.
**How you did the test (engine warm, etc etc) as well as what the exact readings (psi) were for each cylinder may have an impact on what I just noted.
WINGNUT-
1983 - 2012 Ranger & B-Series
01-11-2011 09:52 PM
olthunter
10-26-2003 11:23 PM
