Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-09-2006, 10:41 PM
BuffDaddy BuffDaddy is offline
Garage is empty, add now
BuffDaddy is starting off with a positive reputation.
Post Exhaust Manifold Leak? & Carb Question?
Greetings:
Can anyone tell me if replacing the exhaust manifold gasket on an Econoline with a 144 cu. in. engine is a difficult job? Can I do it from the top without removing the doghouse?? Any tips??
Also, rebuilt carb, engine starts and runs great but seems to run fast speed, hard to kick down. What should I look for?? Will weak return spring do this?? Stiff throttle rod linkage do this??
Your help in the above questions is appreciated, THANKS in advance. Look forward to your replies.
BuffDaddy
  #2 (permalink)
Old 05-10-2006, 06:53 PM
Jimbare's Avatar
Jimbare Jimbare is offline
all alone in the world
Jimbare is gaining momentum as a positive member of FTE.
you can change the manifold gasket from the top, but it is usually a waste of time to start from there.
the bolts will be rusted so badly they will snap off, then you remove the dog house and try to drill them that way.
best way is to just pull the head, use some heat on the bolts to try and lossen them.
that way when they break off you will already have the head off and can drill themout yourself or just run it to the machine shop and let them do it.
you will probably find out the gasket is good, [or the manifold bolts are already broken off in the head], and the manifold is cracked underneath.i would be looking for a manifold before i tore it down.
sounds like the carb baseplate is worn out and needs to be rebushed around the throttle shaft. the "sticking" is the throttle plate binding in the bore of the carb i bet.
make sure all the linkage is free and oiled good before removeing the carb.
__________________
jim
underated and overworked.
  #3 (permalink)
Old 05-10-2006, 09:27 PM
manifold leak.
THANKS Jimbare!!!
Buff
Tags
carb, econoline, exhaust, leak, manifold
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
