FoMoCo Intake Casting Identification? - Ford Truck Enthusiasts Forums
Old 05-09-2006, 06:43 PM
dtherren dtherren is offline
dtherren is starting off with a positive reputation.
I have a 4bbl Intake I am trying to find what it came off of. I did some horsetrading and came up with this intake.
It is stamped FoMoCo, and the # is C50E-9425-C. It is a 4bbl dual plane intake. I need to know if it will handle the Edelbrock 1405, or 1404 Carb or if I need to use the Edelbrock Performer. I would rather stay with original Ford parts if possible.
Thanks.
Old 05-09-2006, 10:06 PM
RacinNdrummin's Avatar
RacinNdrummin RacinNdrummin is offline
RacinNdrummin is gaining momentum as a positive member of FTE.RacinNdrummin is gaining momentum as a positive member of FTE.
well it is definately off of a 289 from 1965.
Old 05-10-2006, 12:02 AM
roger dowty roger dowty is offline
roger dowty is gaining momentum as a positive member of FTE.roger dowty is gaining momentum as a positive member of FTE.
if it doesn't work for your carb there are adapters.
Carb Spacer NS70250 1967 - 1972 F-100 & Larger F-Series Trucks 8 08-06-2016 12:22 PM
Intake Manifold and 4 Barrel Suggestions Needed for a 352 BigMikeUGA 1961 - 1966 F-100 & Larger F-Series Trucks 59 10-25-2015 06:11 PM
Intake swap-352 2BBL brbuchanan 1961 - 1966 F-100 & Larger F-Series Trucks 11 06-11-2015 12:27 PM
4.9L offy "c" intake or edelbrock 1bbl intake TheDudeAbides WTB - Parts & other 0 07-14-2014 10:59 AM
WANTED A New or used edelbrock 4bbl carb....4bbl intake for 302 slick78 1973 - 1979 F-100 & Larger F-Series Trucks 7 01-14-2002 03:57 PM
Tags
302, 351, 50, aluminum, block, c50e9425, c50e9425c, fo, fomoco, ford, identi, identification, intake, markings, mo, sb, small
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
