3rd Fuel Tank - Ford Truck Enthusiasts Forums
3rd Fuel Tank
Old 05-09-2006, 12:04 PM
TheBigJob TheBigJob is offline
TheBigJob is starting off with a positive reputation.
Question 3rd Fuel Tank
I have a 97 F-350 and I am look at adding a third fuel tank in the bed. I want to route this directly to the engine, not to refill one of the tanks I already have. I am currently fabricating my tank, I just need help with the plumbing details. Any help would be AWESOME!
Old 05-09-2006, 01:50 PM
1969fordguy 1969fordguy is offline
1969fordguy is starting off with a positive reputation.
In the Bio-Diesel area of this website they can set you up!
Old 05-09-2006, 03:10 PM
I have a 97 f-350 7.3 PSD and I would like to add a 3rd fuel tank in the bed "hidden" under the toolbox. I am currently building the tank but I am not sure of the plumbing. I want this take to be totally seperate from the factory two. Any help would be great.
Old 05-09-2006, 05:29 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Hidden and totally seperate? Planning on running some red fuel on the highway?
Old 05-09-2006, 05:48 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
i would use another selector valve that would be placed in front of (toward the engine)of the factory valve.
Old 05-10-2006, 10:57 AM
I'm not sure where the selector valve is located, but I will take a look today. Also what kind of pump will I need to get the fuel from my new tank to the engine. I understand there is a pump in each of my two tanks to get the fuel to the engine but the fuel isnt under pressure at this point. Correct?
Old 05-10-2006, 12:55 PM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
If you want a bigger tank in the bed, the best way to do this would be to just unhook the two lines from one of the current fuel tanks and hook them into your new one.
Old 05-10-2006, 03:46 PM
What about pumping the fuel? Isnt the pump mounted in the factory tank?
Old 05-11-2006, 09:42 AM
I'm not sure. Mine isn't on any of my trucks, but I don't have anything quite that new.
Old 05-11-2006, 01:31 PM
YOu can buy a fuel pump that mounts on the fuel lines at a parts store for very little.
Old 05-11-2006, 06:35 PM
cookie88's Avatar
A small, low pressure (7-9 psi) transfer pump would be perfect in that application.
The factory pump on your 97 is mounted in the engine valley, below the turbo.
Old 05-11-2006, 07:24 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Last fall our Department of Tax and Revenue Criminal Investigation Division guys went out to Ohio to learn about a sniffer that samples the exhaust to detect off road fuel, WVO and biodiesel. No more dipping the tanks. I am also expecting a crackdown on WVO and home made biodiesel this year or next if you don't pay the road tax on it.
Why else would you spend all the money for the sniffer if you can dip tanks with a 50 cent tube and catch off road diesel or WVO.
I don't know this to be in the works, but I have a gut feeling it is.
I have not been stopped by them this year yet, so I don't know if we are doing it by dipping tanks or the sniffer this year yet. I have confidence I will know in the next month or so though since it is getting warmer outside.
Dual Fuel Tank issue...HELP! BigRedDooly96 1987 - 1996 F150 & Larger F-Series Trucks 2 05-19-2014 08:57 AM
Dual Tank Help 96 F150 5.0 sboorse Fuel Injection, Carburetion & Fuel System 6 02-27-2011 06:57 PM
Gas in Diesel tank great guy General Diesel Discussion 16 01-07-2009 06:03 PM
fuel tank question hans99 1987 - 1996 F150 & Larger F-Series Trucks 3 10-17-2005 07:10 PM
Leak in Fuel Tank blnmakerr Bronco II 4 09-06-2001 01:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
