EEC Relay Location? 1993 - Ford Truck Enthusiasts Forums
Old 05-09-2006, 03:16 PM
DAJF150 DAJF150 is offline
DAJF150 is starting off with a positive reputation.
Would anyone be able to tell me where the EEC Relay is located. 1993 F-150 4x4, 5sp. manual, 5.0L. I have searched and found out some things. The truck will not fire on some days, and some day will drive for days no problems. I have nearly changed all the sensors, and new dist. and remote ignition module, and coil. Does the 1993 w/ remote module have a ECC Relay? or is that for the module on dist. type only? I have seen what they look like on the internet, but looked all over the dist. area, coil area and fender module area.
Thanks, alot have good day......
No spark from coil, checked a bunch of stuff. What next? monkei 1978 - 1996 Big Bronco 3 08-24-2014 06:48 AM
Duraspark 2 wiring harness with GM 4 pin IGN module JimsRebel Ford Truck Parts for Sale 3 08-10-2014 03:06 PM
EEC relay location? djs556 1987 - 1996 F150 & Larger F-Series Trucks 8 11-28-2013 06:37 PM
1991 F-150 5.8 starts, dies then won't restart test tech 1987 - 1996 F150 & Larger F-Series Trucks 0 01-19-2013 04:36 PM
1986 RANGER 2.3 EFI -WHERE IS THE EEC-IV? bozo4ford Ranger & B-Series 1 10-06-2012 08:47 AM
Tags
1993, 1996, 2003, 50, diagram, ecc, eec, escape, f150, f250, ford, fuse, location, module, relay
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
