Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-09-2006, 02:00 PM
wbw189 wbw189 is offline
Garage is empty, add now
wbw189 is starting off with a positive reputation.
Success!
I am finally having some success in repeating the biodiesel process. The oil I am getting is pretty high titration, around 10mL. Add the base amount for KOH and I get 14.9mL/Liter oil. This was killing me for having to make such a strong methoxide and the yield was horrible (75%). I actually started making a two-step process, yielding soap in the first and biodiesel in the second. I have been adding the titration amount of KOH to 40mL of distilled water and gently mixing until uniform. The soap settles out overnight and pulls the water with it. I siphon off the oil and run as virgin oil and after one hour mix at 130F and one hour settle time I have biodiesel. The separation in this second stage is very quick and the yield is almost perfect in volume. I am filing for my business license this week to buy from a local chemical supplier and should finally be up and running next week.
I remember Fabman saying that a different two-stage method did not work. Is this method listed on a community access page? I am told by a chemist that an acid-base two-stage method could work. The yield would increase along with the cost involved, but the waste from the process would go down. Any input from the trenches?
Thanks, Ben
__________________
Ben
1986 F250HD 6.9L C-6 4X4 3.55s "Rusty"
  #2 (permalink)
Old 05-09-2006, 02:36 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
There are a couple of two stage systems that I know of the base-base method you described and the acid base method.
here are URLs for how-to on both methods:
Base-Base
http://journeytoforever.org/biodiesel_aleks.html
Acid-Base
http://journeytoforever.org/biodiesel_aleksnew.html
If you look at the base-base method you will find that you left some things out at the end of the process, assuming your description was complete.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #3 (permalink)
Old 05-11-2006, 08:39 AM
Thanks, Phydeaux88,
I gave the abridged version in my last post. I have been through the JTF website and could spend weeks reading (driving my wife up a wall in the process). I also have seen both of these methods described in a paper from Iowa State University. Long, but full of pertinent information. I looking for someone to who has experience with the acid-base method. I am curious about any suitable drop in replacements for sulphuric acid. Any ideas?
Thanks, Ben
__________________
Ben
  #4 (permalink)
Old 05-11-2006, 10:13 AM
Phydeaux88's Avatar
According to what I have read it is important that the sulphate ion (SO4)be involved so there is no sub for sulphuric acid. I suspect it has somthing to do with its affinity for sodium in the base stage. Na2(SO4), sodium sulphate, is very soluble in water and thus is easily removed in the wash.
__________________
  #5 (permalink)
Old 05-12-2006, 12:09 PM
I have looked more closely at the reaction, but admit my knowledge of chemistry stops at high school level, so far. I do believe I have found a decent source of H2SO4 with Lab Safety. Others want more money than I am willing to give and/or restrict quantities to more than I will use in five years. Too bad HCl won't work. I could sell the yielded salt in cakes for deer licks in Michigan. Oh, well...
Thanks,
Ben
__________________
Ben
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
